0 Members and 126 Guests are viewing this topic.
NickZ
 Ok, thanks for the reply.  It looked that guy was trying to make the device work like an induction heater. That was what Akula did at first. And is also what Igor Moroz is trying to do now. By making an induction oscillator that can syncronize and work with his modified sign wave inverter,  as the feedback path to keep the battery charged.
  SR 193 used no battery, once started, and only needed 9 to 12 volts to kick start his device, and it had an output 150 watts.  Much more simpler set up, and much cheaper to build. And it does not look like it shocked him, nor does Akula's or Igor's device, all seam to be non shocking magnetic energy, or cool electricity, but still very hot bulbs.
Grumage
Quote from: MenofFather on August 21, 2013, 04:37:42 PM
But how can they explode? I also making this divice but only on about 500 herc. And nothing exploding. Can you draw you schematic? what capasitor nominal voltage of all you capasitors and that capasitor explode?
Dear MenofFather.
Please find attached and amended, your original posted shematic. I can now see why they blew........... They should have been rated at 450V not 60V :)
Cheers Grum.
T-1000
Quote from: Grumage on August 21, 2013, 06:08:50 PM
Dear MenofFather.
Cheers Grum.
Please note the windings on Др1 was changed to high inductance instead of 50T per each autotransformer part. The reason behind that was N. Tesla intention about resonance - much inductance as possible with small capacitance. Also the resonant frequency there was like 1/10th of main frequency driving transistor.
This effectively raised voltages to high level so bottom right capacitor need to withstand it.
magpwr
Quote from: T-1000 on August 21, 2013, 06:41:28 PM
Hi T-1000,Grumage,menofather,bringdownthezog and everyone else,
I have mentioned to bringdownthezog around 1 week after he posted,that i have replicated this circuit which i called it Kapanadze mini with success with ou but without load.If even try to put 1w bulb or even 1k resistor at output.The voltage will drop.Please see attachment.The circuit is running in milisec.
The reason why there is ou is because i find that my function generator was supply the power somehow then i intentionally put 1k resistor to transistor.It did slow the voltage going upwards.
Yes i kill many hours trying to optimize the efficiency to the max by swapping out many components in circuit.
I hope this will stop you guys from wasting more time.Please.This circuit is a good concept but not a ou device.I would not waste my time on this circuit for ou maybe use as idea for joule thief that's all.
Please observe in attached video.I connect and disconnect the switch at the left side and watch mulitmeter show rise in voltage.
