0 Members and 74 Guests are viewing this topic.
NickZ
 Yes, it's one vortex within a bigger vortex field, within a still bigger vortex field.
  So, we need to tap these fields, without explosive consequences.
Void
Quote from: Ntambi on January 14, 2020, 04:42:58 PM
Some Food for the brain
The circuit below is from some of the first videos of Tungus before he changed his name to Akula..
Im gonna be posting to show you the similarities between Akula, Tariel Kapanadze, Weasley, SR193, Tiger2007 and Michel Meyer...
the connection is that all these devices utilise nuclear magnetic  resonance of ferromagnetic materials to produce excess energy...
Now from the circuit:
Lets take a look at object 1 and 3 which are diode bridges... Diode bridge 1 converts the high frequency AC current from the output back to DC into the system (loop) through inverter 2... then the inverter 2 converts the DC current back to AC but this time at 50Hz, its then connected to diode bridge 3 which converts AC back to DC to power the driver circuit 5...
if you read the above statement you can easily tell that it makes no sense, why not connect the DC from the output directly to driver circuit 5 other than converting it to AC then back to DC to power the driver..
Hello Ntambi. Welcome to the forum.
I would agree that the principle behind Daly, Akula, and Ruslan devices all appears to be the same principle,
as the setups are all very similar, and Ruslan of course copied Akula closely, assuming any or all of those circuits
were/are legit.
However, I am not convinced that what was shown in the 'Lithuania experiment' was the same,
but, yes, the underlying principle may possibly be the same in that setup as well.
Kapanadze remains a mystery so far, as he has kept some key details about his circuits hidden.
It is possible that what Kapanadze is doing is using the same principle as well, however.
I think you may be mistaken about the 'inverter' in Akula's early 'self-runner' circuit setups.
I believe that is an AC to DC power supply, not an inverter. Akula was converting
the high voltage AC output from his output coil to a lower DC voltage such as 12V or 24V,
and using that lower DC voltage to feedback back to the input and power his PWM driver. Yes, he may have a
fullwave bridge rectifier before the power supply, but the step down AC to DC power supply apparently still works
even when fed with say around 220V DC (or pulsating DC) rather than 220V AC.
Hello to everyone else as well!
All the best...
Void
Quote from: NickZ on March 01, 2020, 08:26:32 AM
   Well guys, most of the real builders have left this thread, or are waiting for something that really WORKS.
   What is this board coming to then?  NMR...  Here we go again... burning shit up, instead of finding the REAL solution, tapping ambient energy. Not harmful, non polluting, etz...
   Can we get back to that, instead?   If Verpies does not want to test his device, maybe itsu can do it?  Or, someone that can take input to output measurements.
   But, what is the point of bringing up a test of a device on this open source thread, that won't be disclosed? That does not sound right to me.
Hi Nick. I might be willing to run such a device through testing on my bench and
post all the test results here or on Youtube, depending on the conditions of the arrangement made, but it
looks like Ntambi wants to keep it private.
Ntambi:
In such a case, Ntambi,  maybe you can post up a private video of your test setup with any measurements
you are making, on Youtube or on your Google drive or similar, and PM or email me the link, and I could give an analysis
of what I see in the video. That way you don't have to send out your device to anyone. BTW, I am not at all convinced that
the Thane Heins style transformer arrangement is doing anything unusual at all, and from what I have seen,
Thane Heins seems to have come to the same realization at some point a number of years ago. I believe what Thane may have
been seeing with his transformer was actually just a leakage inductance effect.
Ntambi, if your test setup relies on the Thane Heins transformer, then I have doubts about your test setup.
Have you managed to get your test setup self sustaining (self-looped), or are you doing measurements
to conclude a COP >1 in your test setup?
All the best...
void
DavidWolff
Quote from: Void on March 01, 2020, 04:23:40 PM
Ntambi:
Regrettably I need to point out the above statement is floored as even an under graduate in this field would know what occurs by a winding
at 90 deg does.
All the best...
void
At the same time do we really want to make demands on voluntary inventers and isn't Ntambi saying,
he is looking a responsible person of credit and renown to do such tests? I think that is his request.
Dave
Void
Quote from: DavidWolff on March 01, 2020, 09:20:35 PM
at 90 deg does.At the same time do we really want to make demands on voluntary inventers and isn't Ntambi saying,
Dave
Good grief...  :o
