0 Members and 44 Guests are viewing this topic.
GeoFusion
Quote from: NickZ on April 17, 2020, 10:40:05 PM
  Hi Geo:  Welcome back. How goes it? Long time  no hear...  NickZ
Hi Nick,
Yes, busy as always with many things that are important.
I'm just here to give hints that will help.
To understand the system is to focus on the Collapsing field part and using a HV swing right when that happens.
this is what gives it the multiplication method. resonances are used to keep in tune for the system to work and the amount that
you want to receive corresponding to the LC configs. Sync is needed as well otherwise it wont work.
then you have to see when kacher needs to be fired on the correct moment when Mosfet of pushpull is off.
The simple kacher has to be turned off completely by a switch, ( MOSFET) for a brief pulse when the collapse of field is
happening on the grenade. You can add an extra FET that will control the simple kacher negative terminal on or off in fast.
tricky part is that, to sync that specific part.
As what Ruslan said long back or Akula, the Tesla coil/ Kacher is what is doing all the massive output work after.
Make sure you only tap from out put after diode bridge. not befor! otherwise resonance is broken.
Bemf is what this output is, I have seen to much but had to say it.
Important EDITED **
** Nick, I reflected on my old videos where in 2016 was a year I almost had it but it was unstable
Yet it performed as Ruslan did but was limited power yet it did not effect the input at all when changing output
load. In those days I had no idea precisely what was going on but was doing my best to understand, but now I do.
The BEMF was present that day at the output , this is why it did not effect the input.
If there were another tesla coil circuit that could handle higher voltages input such as 60VDC would have made this output greater that day without increasing the input.
this is the video from 2016
The output is not affected by touching the antenna that also shows that the operation is different as I am stating.
https://www.youtube.com/watch?v=1weV296sjHU&t=
Now I know what to do ;), It has taken me 4 years to figure it out since that day.
Quote from: Raycathode on April 18, 2020, 03:50:48 AM
No look again at Nelsons circuit he kindly published he is using that !
Want to try again ?
It does not matter of his circuit now, yet he had some success but we are working on the Akula/Ruslan/Dniester Device here.
Focus on that.
I'm simply helping giving hints and my findings over the period of times.
Cheers
DavidWolff
Geo! I'm not disputing you have something working BUT!
this was Wesley's Lithuanian experiment I don't have one or Ruslan device
but this device worked.
Even Delamorto's talks about it on his Wesley's thread
It makes sense Ruslan does not!
But reports show it will cook you if you use it ! you have been warned !!
GeoFusion
Quote from: DavidWolff on April 18, 2020, 03:05:48 PM
Geo! i'm not disputing you have something working BUT!
this was Wesleys Lithuwanian experiment I don't have one or Ruslans device
Even Delomorto talkes about it on his wersleys thread
It makes sence Ruslans does not!
Hi Dave,
Yes I am aware of this device and have spoken to T-1000 about it many times.
The way this is making energy is completely different from the Akula/Ruslan Devices.
STAAR Yoke device is doing Ferrite Transmutation energy output. this leads to nasty Radiation from the extra material
they had inside the composite of the Ferrite material. those two frequencies Exited it and release it and within certain
resonance. Not sure if it was mixed of Barium inside the Ferrite.
**On thing Ruslan did not talk about nor Akula is how this energy comes about to existance.
that is where they are bastards for a long time... my time invested to see and experiment what it is all about
came to an realisation.
By my findings it is Bemf harvesting and havign resonance all over to keep the balance.
The collapsing field energy and having a brief HV HF pulse right after is what accelerated the output.
This is the type of output when loading it, will not have effect on input. Simple as that.
Ruslan's lastest videos back then for sure did show he using other ways how to
but it is the same outcome and method he is using but difference devices to get it.
Again, STAAR device is comepletely different, Unless you are trying to to nuclear resonance on copper
which is not the thing here right now.
Ruslan did not infact never say what is happening at output but at the video I just posted of my experiment in 2016
RUSLAN did msg me and told me I am close to figuring things out but I had still no clue back then.
Right now, I have.
NickZ
   Geo. So,  can you show us wbat you can do now, with your device?
Utopia Now
Hi GeoFusion
Nice to hear from you   ... I am enthousiast  to learn more from you.
On what frequency does your Grenade resonate.
Are the first 2 layers wound one way and the second 4 layers the other way ?
Anyway cool video`s on your channel.
I heard you talk about the modulation coil   .. sounds like  you call that bifilar coil  or  do i misinterpret what you say i do`nt understand what you said there
Utopia Now     I am Happy :)
