0 Members and 196 Guests are viewing this topic.
kolbacict
Has anyone tried to excite a Tesla coil with a spark gap in this way?
The voltage turns out to be twice as much as usual with one capacitor.
AlienGrey
Quote from: kolbacict on December 09, 2020, 02:33:27 PM
Yea Adrian Guska posted some thing like that about 4 or 5 years back
but in was on one of the threads if you look back and time to wast.
The problem with Spark Gaps is you need about 2.5 kv just to get a fly back pulse
couldn't it be done using solid state components in your type of idea ?
you could sample the charge voltage against a reference voltage fed into a current seance in your chosen
bipolar emitter leg or MosFet sauce leg using a
compactor and use that to feed into an RS flip flop triggered by set pulses at the appropriate timing
simple  8)
control of charge reset latch for fly back circuit  it just needs 2 op amps and a mos fet
AG
Quote from: AlienGrey on December 09, 2020, 09:55:18 PM
simple  8)
AG
Hello or Good Morning,AlienGrey aka AG
" simple 8) " ,I as average intelligent member understand without Physics and EE handbook and English/English handbooks not the mission/scheme /target from You,Your intention/s !
I know,I also wright often cryptical - but is this your intention,too ?
My word2image House ~ Hundertwasser-Architecture
Can you please try to converse your above texture in Physics/EE first lesson and beginner language that morethan only ' freaky EE-slang insider' understand and can try to build such scheme prototypes/clones ?!
Probably You would get also more technical followers and postes repeat !
Or PM DIY help commendation !
Open mind-open letter !
What did you get as electrical/magnetical/thermical-cryonical result from this  'un- ;) detailed' construction ?
Or shall it stay as " Unikat" ?!
How many ,do you mean,can follow all these technical abbreviation ?
Even as professional technician,engineer ?
How many circuits and sub-/-circuits ( wheel-in-wheel :Automat,Differential,Gear) in work process !?
Probably to send it to the Admin as DIY-scheme ? ;) ;D Uncorrected ?!
R U easteuropean ? Not that this would be important,but cause your often slavic-kyrillic links !
We are "Hero" by postes,if you want you get this me given pseudo-title ' elite_member' you can get it - by my side- and I stay as " without ads" !?
Ask the Admin for change !
Or : to moderate me out  :P BVG,I am in VERFASSUNGSRECHT well bewandert,and in VERFASSUNGsSOUL
But : the Best,as SOLUTION : the AG 'Unikat' to STANDART tread ( with AG as MODERAtOR with all rights and all obligations ,Nettiquette ! )
Sincere
OCWL
p.s.: have You at your next ' normal' people ? Give them your texte to read and to translate this in 3d image !        Give them a 2/3d image and let them translate this in their common/er (?) words !
        Not living in an english as mother language country ?
kolbacict
QuoteThe problem with Spark Gaps is you need about 2.5 kv
I use these and the like.
Breakdown voltage is approximately 460 volts.
I remember that Wesley and his Lithuanian friends had similar ones too. :)
AlienGrey
Quote from: kolbacict on December 11, 2020, 07:18:48 AM
What are they some sort of gas filled low voltage spark gap ?
And what are they called and where do you get them from ?
regards AG
