0 Members and 2030 Guests are viewing this topic.
a.king21
Hoppy and all.
Take a look at this video; http://www.youtube.com/watch?v=eUxFuW3JYdY
posted by Wesley.
I am now totally convinced that bifilar coils wound oppositely generate self capacitance in resonance.
This static field is then mixed back into the original. This guy therefore needs masses of static shielding - as does Kapanadze, except  Kapanadze is more subtle in his static shielding.
Also a wet big earth ground is needed with all that static about or the device goes unstable.
Hoppy
Quote from: NickZ on October 11, 2013, 07:07:45 PM
  Hoppy: Even though you've seen good useable output from your Royer/ JR 3.0 circuit, using air coils, just think how much stronger it would be, if a high perm ferrite core were  placed inside, as Igor is showing.
Nick,
The ferrite core only reduces the output on my setup. I've tried all types of ferrites. The primary coil and capacitor will automatically resonate when driven with a Royer oscillator. Close coupling between primary and secondary is important with good insulation between. The turns ratio is also important, so as to build a high voltage across the secondary such that there is still enough voltage available when the secondary is loaded. As a.king21 has found out, tuning is very important and this makes sense as the load has to be carefully matched to the device. In order to get sufficient voltage across the secondary the wire gauge needs to be selected so that is is just sufficient to pass the necessary current to drive the required load, with the necessary number of turns to produce enough voltage to suit the load. Clearly there is more to Kapanadze's devices but getting a very efficient low loss coupling between primary and secondary is a step in the right direction. There are a lot of variables involved.
Hoppy
Quote from: a.king21 on October 12, 2013, 12:28:48 AM
Hoppy and all.
posted by Wesley.
Unfortunately, a device wrapped in plastic sheet is not a very convincing self-runner. The source of power could have been easily provided by a concealed high capacity lithium battery pack. Notice how the illumination level drops off towards the end of the video. This guy is not helping TK's attempt to convince the world that he has self-runners.  :(
NickZ
  Interesting that you don't get any improvement when using ferrite cores.  I do.
Lasersaber has also done extensive testing using many different types of cores, including air core of all sizes. And his 3.0 version using an 8 inch ferrite rod has been his best runner.
Lynxsteam has been able to light 12  7.5 watt bulbs, using his Joule Ringer 3.0 (air coil) version. Thats more than enough to light my house, for free from a solar panel/12v battery.
   Igor is able to light 2000 watts of halogen bulbs, not just a single 60 watt incandescent bulb. But, I don't know if he is doing that with the Royer induction oscillator that he built, as well. His current coil set up is somewhat similar to Kapandze original type set up, or even more like the SR 193 coil system, coil wise, anyway. And possibly also similar to the Russian guy that just posted his version of the TK device, running on just a ground wire.
  Interesting what was mentioned by a.king about what TK had said concerning the bifilar coil used on his device.
  The Russian guy is not trying to convince you, he is only showing that it's possible, just like Akula. I have no problem with that. As we know what can happen to those that do show how it all works.
Hoppy
Quote from: NickZ on October 12, 2013, 04:45:25 AM
Nick,
Try using a Royer oscillator.
The problem with this type of 'look- I've got a self-runner' video demo' - is that it equally shows its possible and likely faked because no attempt is made to thoroughly demonstrate the device by removing the earth wires whilst the device is running and clearly showing all the components, rather than covering them in a plastic wrap. This all goes to give the impression the device is faked, so IMO this type of video is pointless.
