0 Members and 594 Guests are viewing this topic.
MeggerMan
@All
I see that there are various ideas for the device being tried here.
I have not read all the posts as there would be a lot of catching up to do.
There appears to be no mention of an earth connection that I can see in the designs.
The biggest issue seems to be accurate measurement of input power and I can understand this can be tricky if you are using a high current push-pull circuit that can present measurement errors.
You could make an in-line high current filter.
[size=78%]http://www.allaboutcircuits.com/vol_2/chpt_8/6.html[/size]
It would be useful to see a summary of the most successful Kapanadze cousin circuits so far discussed in this thread?
The Romanov circuit looks very good, but is the output greater than the 75W input?
Thanks
Meggerman
NickZ
  Geo:
   Maybe using bigger chokes where you are currently using the small ones may help to dissipate and control the heat. Along with putting it where some cooling air from the fans can blow on it. Looks like you're using ferrite chokes where normally the 1 inch size white and yellow iron powdered choke cores are used.
Thaelin
   Have to comment on the "noob heater" circuit. Having a choke to + on both sides of the coil just
makes two ways to get there. One through only a choke and the other through the coil and a choke
depending on which fet you have energized at the time. Trace it out.
You are burning up good energy for heat in the choke only path.
thay
MenofFather
Quote from: NickZ on October 20, 2013, 03:12:16 PM
  MenofFather:
  I don't understand, so please clarify if it is Akula that is saying that the device overheats, or if it's someone else that is saying that it does not work properly.
First he video divice burn after 20 minutes, I think that divice is so dificult and unstable so Akula not like it.
NickZ
     @ MenofFather:
      Thank you for your reply. That is what I had understood also. That the latest version will self destruct after 20 minutes run time. Thanks for confirming the results.
   Here is another video just posted by Iror Moroz. He finally got a few more of those expensive capacitors for extra storage, connected in parallel to a smaller 4.5 aH 12v battery. And, he is also showing a couple of new inductor oscillators circuits, connected to a flyback coil.
   Hoppy, Igor also got some more meters to show both the input, as well as the output readings, in DC this time around.
   It's Not a done deal, for self charging, or self running yet, but slowly getting there.
  Some of you may find this interesting.
  http://www.youtube.com/watch?v=FmJSirqpKco&feature=c4-overview&list=UUVesA155Der2tRd5vpyYdJw
  GeoFusion: What happened when you connected the iron laminate step down transformer to the output coil??? What's the news so far?
