Utopia Now
Hallo Void
On the Overunitydotcom  youtube video channel    you can find some video`s about he Akula Latern No. 3 device    http://www.youtube.com/user/overunitydotcom/videos
There you can also find a 40 minute video about the Akula Latern No. 3 device
http://www.youtube.com/watch?v=3GtDDQA3U4g&list=UUbcaIfmxRZhnnYVqG81kCZg
JohnBlade video channel on youtube also has 3 video`s about it   http://www.youtube.com/watch?v=7yJytHhudX8&index=15&list=UUa1rRk7Keewb1L0bJbPxNPg
In my online Prezi document ( attached picture ) you can find some more info about it. ( Schematic )
http://prezi.com/fiwgtl78it85/donz-device/      the online doc takes some time to load on your PC  but after 30 sec to a minute  you can zoom and drag or push the > button   in the DonZ Device Prezi document.
This is where i found some info also on the RealStrannik.ru forum    http://realstrannik.ru/forum/49-teoriya-andersena/28770-naglyadnyj-effekt-se.html?start=864#212027
d3x0r
Re Dally GNSI (generator nano-second impulses)
There IS such a thing as a nanosecond generator, litterally a pulse in nanoseconds, but it's not just A part, it's a system.  This works in not a few nano seconds but 10's to hundreds of nanoseconds, but is sub-microsecond.  Although there are writups that a similar choke/cap system can be used for sub-nanosecond UWB (ultra wide band) transmitters.. the DSRD is the final peice that makes the hundred-nanosecond pulse through the coil turn into a few nanoseconds.
The  74HC(T)00 pair is just an oscillator, like a TL494... but with a fixed narrow duty cycle and lower power requirement.
the first 74HC00 is a self osccilator with tunable freqency, and short duty cycle output.
The secon 74hc00 is a pulse chopper, it takes only the leading edge and outputs a pulse... as long as the input remains high it continues to be low.  This can be done with like a JK flip-flop also.
The third part is the transistor which is driven by a narrow pulse (several microseconds width).  WHen the transistor conducts, the energy in the capacitor near it is dumped through the toroid transformer.  Because there is a choke between that capacitor and the real 150V power storage, it takes a short time before it conducts... thereby starving the current through the toroid transformer and effecitively generating a much shorter pulse of output.
The oscillator part can just be another TL494.
A pulse chopper can be made using a pair of mosfets instead with a short RC constant between their turning on; but may not be required if the 494 is used with short duty cycle instead.
The tuning of the capacitor size and choke determine effective output.  The transistor/mosfet driver will be open for a longer time than the output generated through the toroid.
So through a system of parts a narrow pulse is truncated to just the leading edge of the pulse, and that is fed to a transistor, none of these actually work in nanoseconds but actually in microseconds.  What ends up generating a short pulse is a limited power supply with a blocking choke.  Once the transistor stops conducting, the 150V power supply recharges the supply cap at some time after as the choke allows it to conduct.
Clear as mud still?
DD2 is 'side 1' and DD1 is 'side 2' ... forgot to remove some labels.... reading from left to right is 1 and then 2.
Additional note; the cap used should have a low ESR so it can be filled quickly and get maximum current for the shortest time through the toroid transformer
Void
Quote from: Utopia Now on July 24, 2014, 05:59:17 PM
Hallo Void
Thanks!
d3x0r
Quote from: Void on July 24, 2014, 04:14:09 PM
Does anyone know if Akula posted a schematic anywhere for the attached LED 'lantern' circuit?
Can a decent copy of this schematic be found anywhere? I want to try to experiment with this circuit
if I can find a schematic. This is the Akula self running eight LED lantern circuit with the large square shaped ferrite core on it.
Thanks...
Added later: Ok, I found this thread, which has posted schematics, but it seems it was not certain
what the exact circuit was, as Akula apparently didn't post the schematic for lantern 3.
http://www.overunityresearch.com/index.php?topic=2420.0
I may look into the Lantern 4 circuit instead since Akula apparently posted a schematic for that circuit.
http://www.overunity.com/14610/akula0083-light-no3-dual-tl494/#.U9GGCPldV48
