0 Members and 766 Guests are viewing this topic.
John.K1
Erric dollard is the expert on these sort things like Tesla scalar and dielectricity Hope you saw this old movie yet  https://www.youtube.com/watch?v=3uXL4_Yas2k    ;)
Anyway, I am going back to roots.  Disconnect most of electronics and start to tune the Kacher coil once again with the ground connected.  I will be adding by three turns and watching how the light on the bulb change.  Also I think I have a problem to find correct capacitors for this device at home.  I was checking eBay yesterday to find some same like Ruslan's. Unfortunately I found only lower ratings. Need to continue to search.  Also, I was thinking about that Ruslan's PushPull . The PCB looks to me really kind of very professional. I wonder if is it possible to get some of the shelf.
Hoppy
Quote from: Jeg on November 17, 2014, 04:06:40 AM
When i started this project before some few months, my intentions was to replicate the effect, and understand the nature of this so to repeat it in a controlled environment. During these months, i gave all myself to this research. I have tested all possible connections with the most basics. Just a yoke, a kacher driver, two tuned coils and that is all. I have tested 4 different yoke configurations, i have changed 5 times my grenade, and i have wind more than 6 different inductors in terms of form, turns and wavelengths. The earned experience is something that can not be described. But the most important.. i met you guys! This is something even more important than the project itself. And i think it is the right moment to say a big thanks to you all. So many researchers on this thread, so many nice fellows that deliberately share their ideas and efforts. I still don't have a self runner but i already feel like a winner. About assumptions and no-purposely misleading, what can i say. Everything is needed. It is better to fail while trying than not trying at all.
Hi Jeg & all,
Its great to talk with fellow experimenters in this community. Nothing ventured, nothing gained.
I've been looking closely at my Karcher waveforms and comparing them with those in Ruslan's video posted earlier by T1000. Mine are not quite the same and I think this is something to do with our Kacher builds being different. I'm fairly sure that although he is using what appears to be a common-mode choke, the two coils are not connected to work common-mode. We need more detail on his oscillator circuit in order to replicate accurately. Another puzzle solved for me, is why Ruslan's scope was showing 3.16293MHz, when mine is reading half that frequency. The puzzle was solved when I realised that I needed to disconnect the antenna and then found that my scope read around 3.2MHz.
I did some more experimenting with the 'URFA effect' and I now know that he has his kacher tuned for maximum spark length and current consumption. The reason that the lamps dim when his hand comes close to the antenna is that the Kacher secondary voltage increases, causing a corresponding increase in current. This current 'steals' current from the push-pull oscillator, which in-turn reduces the induced current in the 28T yoke / lamp load circuit. However. I'm still intrigued at how sensitive his antenna is to hand capacitance. The total supply current actually increases when the lamps dim! URFA clearly has his device tuned very differently to Ruslan's.
NickZ
  Yet, Ruslan's hand movements by the antenna coil don't seam to affect the bulbs output, at all. How can this be? As most Kachers are sensitive to this. But, not his.
MenofFather
Here is something like this, thats fallowing from Ruslan explanation from conference if for somebody interesting. Only after choke on kacher probarly must be electrolytic capasitor with big capasistance and resisitors can be other on kacher and zener diodes.
John.K1
Nick,  That's not true. In one of his last videos he shows when he moves hand over the coil it has impact on the output. Also the output of his lamps were not stable and he was saying he will need some stabilizer.
