0 Members and 122 Guests are viewing this topic.
Hoppy
Quote from: magpwr on November 24, 2014, 06:02:46 AM
Hi hoppy,
You may want to try either adding more bulbs say 300watts and try verify amp draw.Another approach try reducing duty cycle a little to sèe if bulb can be lit and check amp draw again....
Yes, I've done all that and bulb brightness always relates to amp draw.
Jeg
Quote from: Hoppy on November 24, 2014, 06:37:44 AM
Hi Hoppy
Is there any case of not properly tuned coils?
Have you verified that both grenade and inductor lines have the same HF peak?
itsu
Quote from: magpwr on November 23, 2014, 05:48:40 PM
hi itsu and everyone,
Previously only myself and Hoppy have achieve this "pulsing effect" on the bulb.Both of us applied 60th sub-harmonics for the circuit...................
Hi Magpwr,
i don't know why you keep refering to the below screenshot when talking about 60th sub-harmonic.
Surely you can see that with 1 period of the big sine wave we have 3 periods of the smaller tesla (Kacher), meaning
there is a 1 to 3 frequency relationship, not 60
Or do i see/understand that wrong?
Regards Itsu
Hoppy
Quote from: Jeg on November 24, 2014, 08:55:53 AM
Hi Hoppy
Yes.
d3x0r
So having the cap in series with the load, I'm able to use the magnet wire wound ferite that was pretty accurate in 1/2's and has a good stacking at the end... and get the appropriate output.
The one other longer ferrite does not work as well (better with cap)
So I swapped back to my 12g kapagen, and used signal generator on a few turns of wire and am able to tune to 745kHz and with cap in series get appropriate output... with a square wave also able to tune to 143kHz and get a low resonant point...
but if I drive using the cuffed coil... I have to go up to 1200Khz to get the high level resonant point... if I use just 8-10 turns it goes down to 840something... so the higher the inductance of the driver, the higher the drive frequency has to be....
