0 Members and 626 Guests are viewing this topic.
skywalker66
Quote from: T-1000 on December 12, 2014, 08:26:07 AM
For Tesla extra coil he did not mention winding directions but it is only one way to find out  by making one :)
Also all receivers in N. Tesla experiments had opposite direction of windings...
Thank you !
John.K1
Quote from: Hoppy on December 12, 2014, 08:29:49 AM
Duracell last longer, much longer!  ;D
https://www.youtube.com/watch?v=TYPuN6wJC9E
Or like this : https://www.youtube.com/watch?v=1Dw8_AEeA54
Don't lough, I was trying to figure it out last week :D
Edit:  Two Lithium batteries, one diode, two LEDs- no caps or coils. ;) Self recharging effect :)
d3x0r
wound a few more kacher secondaries; have one that will work at 1.78Mhz, and that immediately gives resonant output on the 48/48/24/24/12/12 small core grenade.  It's not a lot of power.  I ordered some 1.7kV .47uF caps; but they were marked wrong on the site and they were actually 0.047; which explains why they were so much cheaper than the other .47uF caps from the same company.  Got some 1.5kV schotkey diodes too... no problem getting to 800V (at lower frequency)
at 1.78Mhz the power draw is very minimal , and transistors do not heat; but it's doesn't have enough capacitance to light an incandescent... have to wait longer for correct caps.
Even at 31.8V is only 0.05A ... but again that's no current loads...
actually trying to get to the 3.5Mhz range... on top of the 1.78 I have the back dips from the higher frequency... and a higher frequency is a sharper slope of current.
antenna transmission is weak at that point.
WOund another that was about half the turns of the good one was still stuck down at 1.7Mhz when connected, and couldn't get good output; and increasing voltage to a level broke the oscillations... but now I'm down to like 20-30 turns on the secondary... think the one i have that's good is about 60 turns
guess I should swap grenades
blew up 2 more transistors turning on the power too high with the resistance too low... should include some 5V zeners on the base to ground of the kacher
starcruiser
could try a different tesla coil driver
Regards,
Carl
starcruiser
Use the above circuit, which self tunes the driver and use a auto transformer (variac) to adjust the input to the primary to see where the HV sweet spot is on your grenade coils. Very simple design here and no more blowing up components. I would suggest sweeping the coils of the output stage to determine how many winds are required to tune the primary to the secondary to maximize the transfer and reduce current consumption. remember to wind the primary opposite the secondary to improve isolation.
I would suggest the high frequency diodes for the bridge rectifiers if you are looping the output directly. I think an inexpensive inverter can run all this off a 12V deep cycle very nicely.
I really see the torrid (yoke) setup is nothing more than an inverter (switch mode PSU), a 60hz setup would just need the capacitor adjusted (value) to match the 60 or 50 hertz line rate on the grenade 25t bifilar coil.
Regards,
Carl
