0 Members and 468 Guests are viewing this topic.
Bat1Robin2
Nickz,
Hey i just smoked resistor R26 , 1K ohm 1/4 watt.  I am going to upgrade it to 1 watt. Are there any other resistors i need to upgrade from 1/4 watt.
What about  R21, R22 gate driver resistors. What is that resistor for anyhow bemf ?
MenofFather
Quote from: Void on April 02, 2015, 10:04:01 AM
Us English speakers are missing a lot of the details of those videos that are in Russian. :D
All the best...
I calculate frenquency of Tesla coil in Ruslan video by squres in oscilioscope. And it is about 450 kiloherc. And calculate paches frenquency, it is about 125 herc.
Ruslan giving to Tesla coil 150 about volts DC. It consumps about 100 mA (15 W). Ruslan use transitor IRFP460 for Tesla coil. And going pulses trought 3 wave. Example: Tesla coil have 460 kiloherc resonance frenquency, pulses going with 230 kiloherc frenquency with 25 about precents duty cycle.
In Ruslan that divice with two big pipes is voltage converter. Who convverts from 14-15 volts to about 150 volts for Tesla coil. And on that transformer is wounded second secondary who gives squres to that emalated wire who wounded on second pipe and without toroid, that emalated wire is like inductor...
That DC converter have frenquency 8 kiloherc (so we hear sound in video).
Output coil  wounded in bifilar way (but inductive bifilar, maybe Tesla bifilar). One end output coil is grounded. Comon minus is grounded. Ground end of Tesla coil is grounded. From output coil gose directly to inverter. Inside inverter is capasitor who resonate, so on output coil can be sine (while on emalated coil is restangles).
Ground here is can be critical. With ground conected to steel battery in home can not work. And ground wire is long. And that divice works is one place in other place can not work, around it must be many free space.
From output coil also gose wire to bridge rectifirer from 4 diodes and to capasitor about 450 V and 12 uF, then to load two energy saving lamps 23 W and 25 W or something similar watts.
Here I write about that divice https://www.youtube.com/watch?v=ZfjEsRVO_og
Inverter who making selfrunning works from 78 about volts to 230 about volts. Output it have 14.4 volts. Ruslan starting his that divice from 15 volts power supply.
magpwr
hi everyone,
Finally i got the chance to test out my brand new clamp meter UT-207A on the 1 wire which is connected from my 1kv  ~10nanosecond generator to Earth.
Current measurement attached.
I managed to open up the the small 220volts inverter and found that nearly all inverter transformer does comes with a usual yellow protective tape.
I then had a "total recall" base on one of the Ruslan previous unboxing video which he removed screw while device is in operation.
I recall seeing similar step up transformer in one of the 2 boxes which can be used to power the tesla coil or be can be used to step up around 340volts DC to around 1000volts for the 2 PIO capacitors which was connected in series.
It is possible to use 9volt battery to get PIO capacitor charged up via 2 stage -transformer extracted from inverter then rectified once again to get around 340vdc then this is stepped up via mazilli oscillator for high voltage.
My previous experiment on mazilli circuit which was conducted last year revealed that it consume less than 10watt for no output connection.PIO capacitor once charged up would hardly require high current.
My experiment with nanosecond generator with a existing tesla coil revealed that Tesla coil base on the typical winding which we have done is not able to handle nanosecond pulse very well.
The best solution i can think off at the moment is to create segmented winding or example every 10turns on pvc pipe we give spacing between every 7...10 windings.This will in theory reduce the capacitance in the windings.
The end result the tesla coil would able to handle nanosecond pulse easily with lower loses.
The objective remains same for now to increase current flow to earth.
Void
Quote from: MenofFather on April 03, 2015, 06:12:05 AM
Thanks very much menofFather.
All the best...
NickZ
  Void:
   Can a bulb be placed on the earth ground line to see if it can be lit comparable to the 1.6 amps that your new meter is reading?
I trust the bulbs lumins levels more than meter readings. Maybe some salt water can also be added to the ground lines.
   I also bought a new digital meter, to test the amps at the output, up to 10amps. But, it won't work for me, since my output is not rectified to the bulbs, yet. And the AC readings are all over the place due to HF.
   I test my feed back path circuit by placing a 12 to 24v bulb at the capacitor terminals, and it does light well, and it already burned out one of my test bulbs, so this shows me that the feed back is working pretty well, just not to the degree needed, to self run yet.
   I found that since it's very dry here now, I need to wet the ground around where the earth line goes, or there is not much conductivity to earth ground. That's why I ALSO placed a ground line inside my water well that's in the back yard, similar to what Akula is doing with his ground.  I should also find an old radiator, to try out, as well. Since the old Kapanadze back yard video device, with it's two ground lines, is still the best output from any device of this type to date, something like 5000 watts, or so.
Without a nano crt, most likely.
   Geo: What is Akula adjusting in that last Akula video that you posted a few days ago, to obtain resonance? Any idea?
