0 Members and 162 Guests are viewing this topic.
Tomtech29
 :)I see that: br549 something that creates a sense of good I throw it to the idea..
sorry guys like rubber tore the pants not the subject so much in another this experience
Tomtech29
-I expected something on those impulses that it looks like Akula had a sine waveform and Ruslan is about growing as a signal pulse reverses the polarity of? as it is only half the course of one half of the top and bottom mugby somebody in two words to explain
where the signal is visible on the grenade?
I this is a preview of the course in which the site is connected to the oscilloscope and how 1...Kw (Probe)
or what is on the base of transistor that goes on Tesla There peaks serve NS?
T-1000
Hi all,
In https://www.youtube.com/watch?v=zBAB5uYAeA8&t=11m29s Ruslan is talking about creating standing wave between grenade secondary and primary coils and hitting with pulse from Tesla coil to move charges. Also he talks about ground cable being winded into coil for a reason - to tune standing wave peak to be exactly under top load of Tesla coil where is inductor.
I just asked in comments there below to be sure - "So, the underlying principle of device operation is by hitting with electrical pulse over capacitive link to magnetic standing wave for making power amplification effect?"
Will see if he will reply to this and hopefully this is right on spot... ;)
Cheers!
Dog-One
Quote from: magpwr on April 27, 2015, 12:19:05 PM
For kacher high voltage means high current.But no current to single wire to Earth wire detected with kacher.
Magpwr, I did a little research last night and came across something practical to share...
Everyone knows about a capacitive discharge circuit (see attach).
There two ways to wire this:
  One way is like the attached image, where the coil is connected to ground.
  The other way is to connect the high voltage to the coil side and charge the pulse cap through the coil, with one side of the pulse cap connected to ground.
There's a subtlety here in the the reference point; the function is the same.  With this CDI design, the pulse cap is completely discharged before the next cycle, but keep in mind, when the SCR triggers, you effectively create a tank circuit that will ring down until the SCR releases.  So all we need is a small trigger signal and a pulse capacitor that is matched to the primary of the Tesla coil.  We also remove all the filter caps from the output of the high voltage source and add a small inductor in series that will build a magnetic field while the SCR is triggered; once released, the magnetic field in the small inductor will immediately recharge the pulse cap.
Not sure if anyone has tried this, but on the surface is seems very straightforward, effective and reasonably easy to tune.  The other advantage is in the ground reference which may prove very useful to understand.
Thoughts?
Dog-One
Quote from: T-1000 on April 27, 2015, 02:22:20 PM
Stay with him T.  He may not even know exactly how his device works, but I'm certain he knows >100 theories that do not work or pan out by his experimentation.  Once we get this narrowed down to a handful of possible operating modes, we can engineer the principal however best suits our collection of resources.
