0 Members and 76 Guests are viewing this topic.
Enjoykin
Quote from: NickZ on April 27, 2015, 09:03:01 PM
Enjoykin:
I viewed those videos, above, and see nothing that would indicate that it is a "successful" replication.
That is, the device is NOT self running, as it's running on 24v, and 6 amps input, to partially light a single smaller bulb on 144 watts. Or not?  Maybe I missed something?
Listen NickZ, Andrei device is 225 Watts self-runner at 220V, but his problem is extraction more power than 225 Watts / 220V. In my oppinion problem was caused (sure about 90%) by bad grounding and erroneous ground lenght conductor - which affect position of Scalar nodes and antinodes at Grenade. Other 10% in my oppinion could be: lower HV output from Brovin Katcher, erroneous position of Katcher primary (inductor), small value of load output capacitor or high capacitor ESR. Best options are old Russian pulsed capacitors like on Dally pictures. Can be obtained easy from Ebay. What most people confuse are winding orenatations start/end points and correct placement of coils. See correct Grenade winding diagram in my previous posts.
In my oppinion for power of 5kWatts or more we need great mass of cooper in Grenade coil. This mean - 10-12mm2 diameter of cooper wire and whole weight of Grenade coil about 4kg..5kg. Or higher. Remember Tesla Magnifying Transformer relation Mass of Primary = mass of Secondary.  Comparison can be our Sun and some surface on earth. As surface is bigger more Sun energy will absorb and convert for example to heat. No surface (no Mass) no heat !! Simple !!
To summarise: Grounding should be made as Roman Karnouhov did (see ground conductor diameter of his 1.5kWatts BTG) - also see diameter of Kapanazde grouning conductor. Good Grounding need thick litz-wire 15 mm2. Lenght of conductor can be easily tuned reeling on bundle. (see again Roman and Kapanazde example).
I have gave people all basic informations because the Roman Karnouhov concept is correct. Everything depend from Do It Yourself Builder.  ;D
NickZ
  Ok, Enjoykin maybe I did miss something...  as I don't understand what he is saying. I'm interested in knowing what is going on.
  But, I see no battery, and I see 24v 6 amps reading. The bulb is not lighting to 225w output at 220v, nor does it look like a 225w bulb. You wouldn't be able to look at that bulb or take a video up close, if it were lighting that bulb to normal grid power.
  His kacher's secondary coil looks too long, the spark at the antenna is weak, HV spark, with little current,  and it's primary coil is not like the recommended size, also the antenna coil looks skimpy.
Where is the proof that it is self running?
There's wires all over the place. I'm not saying that it's a fake. So, please explain.
  PS. Kapanadze's 5kw device, did not need a huge mass of copper coils to produce the shown results.
Bat1Robin2
I agree with nick power supply shown on the left and not self running.
Not even a simple input vs output measurement. wow. That was not self running but at least it has no closed boxes.
https://www.youtube.com/watch?v=p2ORAqDfvHo&feature=youtu.be
I still have not heard from anyone what efficiency they are getting.. 70% 80% 90% ??
Who has replicated and what did you get for return efficiency?
nick what do you have so far?
This is all about reaching 101 who is close?
Enjoykin
NickZ, simple he doesn't know how to extract more power from his BTG. Bigger bulb is 200W, smaller 25w. In my oppinion problems here are impendance mismaches. (take notice how output power and light bulb brightness has changed when he shifted inductors right-left. This kind of devices imply mandatory use of vector analyser for perfect tunning input and output impedances and maximum output power. Precise tuning here is job for professionals - like me !!   ;D  ;D
About Katcher you have right - his secondary coil is not correct, and has not extra coil copper strip as i have shown in my earlier posts. Extra coil must be in opposite phase to secondary. Also has not ferrite rod with two small CW-CCW coils for fine tunning of scalar nodes and antinodes.  He need change both inductor coils - at Katcher and Grenade. Good stuff that he was divided tube at two parts so he can easy change winding directions of his coils. Katcher resonant freq. is 1.432Mhz and consumption 12w. Katcher wire lenght is 38.956 m. Push-Pull running near 14kHz and tuning capacitor is wima mkp 0.47uf/2kV.
The proof is 1st video from 21 April 2015. Maybe he will upload newest videos.
For more informations ask him personaly
- Andrey Induction -
https://www.youtube.com/user/Andrey4354/videos
About Kapanadze - Do you know how much was mass of his 5kW device and how much copper conductor he has used ??
ps: Some very famous and old members here have own BTG self-runners, but keep the mouth shut !!
Is it enigma for all ?? Nothing change in human behaviour !!   ;D ;D ;D ;D
Hoppy
Quote from: NickZ on April 27, 2015, 10:28:08 PM
IMO you have not missed anything. The bulb is very unlikely to be running at even 100W, which is around 70% of the 144W input power.
