0 Members and 109 Guests are viewing this topic.
NickZ
  Hey Void:
   You've been lost in space,  as well?  Good to see you posting here again.
   Could use a few more replicators around here. Gets a little lonely, at times...
magpwr
hi everyone,
This is my final hardware upgrade for the Tesla-Transponder Experiment.
After this stage i will be experimenting with harmonics base on new winding for my special tesla coil at later stage then finding suitable harmonics which would match with harmonics of the kapanadze coil. :) ;) :D 8) .
If it was resonance we can easily apply formula as what was taught.But since i am playing with harmonics only the spectrum analyzer can reveal if there is interaction between low and high frequency harmonics which is fixed eg:kapanazde coil. :D :D :D .This is the hint.
The primary goal in replacing 2 vital components capacitor and another version of SIC Mosfet resulted in reduced power consumption and at the same time increasing Amps reading to the ground.
This after finding the sweet spot which my 1KV variable Air capacitor yielded the best result.I then replaced this capacitor with a fixed value 68pf 2.5KV High Q,Low ESR Capacitor suited for use in RF or pulse application.
Replacing the capacitor did reduce power draw a little more from previous experiment nearly 20watts.
The final upgrade in order to further reduce power consumption is to replace the High Current Mosfet to little lower current version 40Amps pulse rating 1.2KV  CREE SIC MOSFET "C2M0160120D"
This mosfet gate capacitance mere "525pf" down from the 950pf base on previous SIC MOSFET used.
This ensure i don't have to worry too much if i have applied insufficient tantalum polymer capacitors at the IXD614 mosfet driver(23.5volts boosted from XL6009) supply rail at later stage during circuit design. :)
The Antenna coil using solid copper wire eventually needs to be replaced by coaxial cable using just the outer layer.This would increases the skin effect a lot more since surface area of coaxial cable is more than solid copper wire.
I am a little concern since a Russian forum site went down for couple of days or weeks.-http://realstrannik.com/forum/ustanovka-kulabukhova.html
If anything happens to this site do provide hints of new links in the comments of youtube.
Tomtech29
Hi.
just keep it up
works very nicely going forward.
- I moved last test on this circuit and I'll take my spare time for system-based. (Now it's time for a more difficult task)
a slightly different comparison:
I made a video but still nothing from others :-[
until next time.
Tomtech29
The use of rectifier diode to earth. :)
-and so it looks like it does not exist.
Tomtech29
...Today dug all this stuff on this forum and I did not know from some of my assumptions have you discussed and I day back was creating something that already was ::)
who does not ask it wanders like a blind man.
Here I come back to :Magpwr
you have a lot of behind -question for you is : to select the harmonic :I need to know what and how to do it properly ? and how do we know that it fits with 27kHz 1.70Mhz
"This would indicate that I will need additional windings to 27kHz" (because increasing amounts of uF only reduce the frequency down) or actually combines?
how it works in practice ,and whether the establishment( type of ground) has an impact on changes?
let it be here Paste:
