0 Members and 411 Guests are viewing this topic.
NickZ
  John.K1:
   What voltage are you using for your Kacher input, 12v, 24, from a battery or PS?
   The heating of the transistor can be lowered by increasing the resistor value of the transistor's base resistor.
   Anyone that can't get much light output from at CFL placed next to the Kacher secondary, can try adding some flyback ferrite pieces into the Kacher's pvc pipe, which can then be adjusted for best light, or for best frequency.  The best brightest light may not be the best running frequency, so you can adjust the kacher frequency, with ferrite pieces to see the best "effect", that it's pulses are causing on the grenade.  Also, less voltage is needed to have the same effect as using a higher voltage, and having transistor overheating issues. Lower resistor value to the transistor base, as well.
  So, the Kacher's frequency can be adjusted, by changing turn counts, moving ferrite pieces in the former pvc pipe, and adjusting the trim pots on the Kacher circuit.
  The Kacher's ferrite tuning balun is there for a purpose, so don't just skip it.
It may also count as the 4th Tesla coil. Or not?
  Question:  Although I don't have my scope yet, I do have access to a function generator.
Is this something that would help me to tune my device? And if so, how would I go about it?
  An interesting article about Tesla:
  http://www.huffingtonpost.com/2015/07/10/tesla-quotes_n_7771358.html?ncid=txtlnkusaolp00000592
John.K1
Nick,
My input was around 1.5-2A @ 24V
I used 24V - two small 12V led 7Ah bateries in serial.
Regarding to my Kacher, sure I was tuning it by variable resistor to the base.  But this also change the shape of the signal on the collector. I found the sweet spot between consumption and output power (just to see the CFL illuminate)
Yes , the ferite core with two opposite coils at the entry of my kacher has also impact on the output. I had to rewind mine with the couple turns of  thicker wire. Any other type was overheating.
I remember there was some suggestion to use several  parallel power transistors 3055 in UFOPolitics cold electricity device. Just curious if the same would help here to to get of the heat. As the transistor warms up, it also change characteristics and this is not desirable.
NickZ
  John.k1:
  That's interesting that your ferrite rod wires are getting hot. I've never had any heat on those coils.
Are those turns made with copper wire. Maybe try different wire, but with the same amount of original number of turns, 5 and 4 turns.  I think that solid copper insulated wire may work best.
  I'm only using 12v input for now, as I don't want to fry my fets yet, using higher voltages.
But, I notice that it may take a higher voltage to actually trigger the effect, which does not show itself when only using 12v. As the voltage can drop to less than 12v, and when the load from the bulbs is fully on, sometimes for me, it can drop down to 10.5 volts, or less. My push-pull can still run down to about 8v, even while lighting some bulbs, (25w and a 50w bulbs) on as little as 2 amps, as I've shown in one of my videos. Of course those bulbs aren't fully bright.
Dog-One
Quote from: AlienGrey on July 11, 2015, 05:03:24 AM
Dog1 and all, sorry to be a pain but do read the F manual  RTFN (Tesla info on the net and ruslan interpritation. the tesla coil is 1/4 wave to get the voltage up to dump on the current pulse, if it was full wave it would be 6 Mhz but the turns would give little volts, also it has to be bang on!, the 1 to 10 or 1 to 100,devide, it's because it has to be in resonance do you understand what i'm saying ! Ruslan gets it to work cus he sticks to the rules. Just understand what he is telling us.
I certainly have read "the manual", but I'm not clear on the understanding here, so please assist me in this a bit more until I "get it".
The way I read it is the Tesla coil must have 1/2 or 1/4 the length of the wire as the grenade coil.  I went with 1/2 because 1/4 appears way too short.  From what you are implying, I should forget about wire length and focus on wavelength calculated using the speed of light and desired frequency.  So which way is correct?
For now I think I will stick with the Kacher method, tune the primary and secondary best I can and see what happens.
If I can get anywhere close to this:
https://www.youtube.com/watch?v=2UFEbY2vEfs
I should be in business.
Void
Quote from: madama on July 11, 2015, 11:59:32 AM
thank you for answering all together
Madama, in another thread you had started I had already answered you that the only somewhat potentially
credible replications of a device similar to Kapanadze were the ones done by Akula where several people
have seen his devices working in person, and were able to inspect his devices up close, and none of these
people reported any obvious tricks that they could detect, that I know of. Another guy named Ruslan claims to
have replicated one of Akula's self running devices, but as of yet I don't know if any reasonably trustworthy
and qualified independent party has had the opportunity to examine Ruslan's devices up close and report back on
whether they saw anything suspicious or not. So you have Akula and Ruslan as being possible replicators of devices
similar to Kapanadze. Akula is working with some German business people to market his devices, so you could contact
them if you are really serious about looking into this further. It is quite possible that they could be looking for large
sums of money however. It is not likely that anyone who is interested in commercially developing such devices
is going to let the technology go for cheap.
Akula's business contact for people interested in his devices:
akula2015@gmx.de
You could also contact Kapanadze directly as well via the contact info he has listed on his youtube channel, but
Kapanadze is known to want money just to view his devices. Have you already contacted Kapanadze? If so, what
did he say to you?
