0 Members and 78 Guests are viewing this topic.
d3x0r
Quote from: verpies on December 13, 2012, 10:56:44 AM
It looks like this:
Well thanx Verpies, I don't understand what I'm looking at in those pictures though....
itsu
Quote from: d3x0r on December 12, 2012, 09:35:56 PM
Although, your homemade coax should do the trick there.  I wonder how exactly the electron flow looks in a good cylinder ( like as it's self inducting, it's going to cause more helical paths...)  and although the propagation is actually in a skin effect (so the outside skin is best right?)
Hi d3x0r,
from this link (scroll to lower part) you can see how the skin effect is working in a coax structure.
The inner conductor is more and more used to its outside, while the outer conductor (shield) is more and more used to its inside
http://www.iue.tuwien.ac.at/phd/nentchev/node48.html
See also this link for how current and the magnetic field (almost noting coming out) is flowing at low frequency:
http://www.iue.tuwien.ac.at/phd/nentchev/node46.html
Regards Itsu
mihai.isteniuc
Quote from: verpies on December 13, 2012, 03:52:59 AM
1) 18AWG ....
I would like to understand why this differences between apparently same type of diodes. (I don't expect any answer but if someone has any ...). My 1n5408 provides 10-12ns very easy. 1n5406 does nothing. I'm sure verpies after this (his) test will not recommand 1n5408 as a good DSR diode.
Quote from: verpies on December 13, 2012, 04:34:13 AM
When the pulse ....
Basically I was seeing the things in the same way, but my disscusion partners fail to understand the (very important) impendance mismatch.
Thank you for both your answers.
Mihai
d3x0r
Quote from: itsu on December 13, 2012, 01:25:03 PM
Hi d3x0r,
Regards Itsu
Okay, I'd believe those, but those are representations of a current flowing through the center conductor only, not through the shield (which normally is grounded)....
itsu
Quote from: d3x0r on December 13, 2012, 03:34:32 PM
Okay, I'd believe those, but those are representations of a current flowing through the center conductor only....
Hmmm, i think it shows the current and magnetic flux in both the inner AND outer (shield) conductor.
Anyway, i tried severall coax cables as L3 coil, but all 3 behave similar when pulsed with 1.5Kv nano-pulses.
http://www.youtube.com/watch?v=5ah6nXOEcR8&feature=youtu.be
Regards Itsu
