0 Members and 325 Guests are viewing this topic.
Jeg
Hi guys :)
After a long absence from experimentation due to some personal problems, I come back to this never ending Ruslan story. I read you from time to time and I see that still there are many holes in the principal theory behind Ruslan's devices. I found by accident the following info. Pls read at page 2-45 about the coil shorting technique.
http://www.google.gr/url?sa=t&rct=j&q=&esrc=s&source=web&cd=2&ved=0CCUQFjABahUKEwjjgb-VvfbGAhXFXRQKHWfTANk&url=http%3A%2F%2Fwww.free-energy-info.com%2FPJKbook.pdf&ei=L5uzVaOuF8W7Ueemg8gN&usg=AFQjCNEqdncbXA75StDaV_c-0zXSlq9mZQ
It is very close to what we are trying here and I'd like to mention some things.
First of all, to discharge a magnetic field when this is at its maximum value, a one side pulse is needed and NOT a sinus wave. So Katcher coil has to be rectified before its thick pipe antenna.
Secondly, to form a capacitor between katcher's antenna and grenade so to pass this high voltage spikes, there has to be a common ground reference. Just think what we need to charge a cap through a high voltage source and apply it here considering antenna and grenade as two cap plates.
Third, pls see the circuit diagram of page 2-48. You will notice that there is a switch which connects and disconnects the load from the output capacitor. During one cycle the cap is being charged and during the other cycle is being discharged to the load. Exactly the same as Carlos Benitez does. Perhaps the old folks here remember this small black thing which is hiding near the output bridge at one of ruslan's devices. We had assume then that perhaps it was a mechanical electric switch but we never tested it to see its affection to the overall operation. I smell some food here. Perhaps charging the output caps during positive LF cycles accompanied with high frequency magnetic field discharges, and discharging them during the negative cycles to the load, is the way to go.
At the end, just an assumption which actually is a proven fact.
When a magnetic field collapses, a high voltage spike is being developed across a coil, in a try to keep current flowing through. This is the well Known bemf. If we artificially make more than one field collapses during a cycle, then more than one spike voltages will be added to the output voltage. It can't be more simple than this guys.
Happy experimenting ;)
GeoFusion
Hi Guyz,
  magpower,
Thnk you for trying the First Akula Device Setup as the voltages are extremely good :)! 2.8KV, that is a nice result.
we should have the opportunity now to able to replicate  Akula's first device and see how it goes,
Maybe by doing this will bring changes in our understanding and might able to replicate the other types of these devices they created.
https://www.youtube.com/watch?v=Ltf3UEv1Wnk
Might not be the best Energy Converter system that can run without ground, but having it will open doors ;).
Try to bring a Good cap (450V-1000V)  in resonance in series with an inductor anto a coil similar like what Akula was using. see what we will achieve. Don't forget the Drossil inside, a coil that is shorted with a Cap, for more output and to reach resonance with it.
That will be one the 3 Turn coil on yoke to the cap and Inductor resonance.
the 28 connections is what I see should be connected in a way like how a tesla coil needs to be connected, on end at ground
and one end hot in some way configured onto the output coil.
The only thing I am missing now from the First Akula Device is to know how preciesly the 28T wires are connected thru out the output
coil.
SolarLabs,
Thnx for the Pdf. it has some valuable info regarding the waves and pulses, check it out guyz.
Jeg,
Thnx for the info, and yes makes sens to what the device does. must bring this all in practice.
Void:
Thnx for the info about the TL494 types that go beyond 1Mhz, this is important if needed.
Thank you guyz to the link of the Push pull and Tesla coil drivers from Oleg.
Btw I can give the schematic I used for my TL494 simple drive I am using on my current testings.
I recently saw something been posted about Aether Energy and harvesting from ground.
reminds me of my Ground dependent device using Flyback, without it , it won't produce.
Happy experimenting and be safe! The outputs are not safe!
Yet the ground is safe.
Cheerz
Hoppy
Welcome back to the confusion Jeg.
Kapanadze went to the trouble of not only procuring a particular type of coax but also stripping-off the outer sheath and braid to be suitable for winding his grenade coil. The inner core of the coax covered by the thick dialectric of the coax may have been important to form the dialectric between the inner conductor acting as one plate of a capacitor and something inside the grenade tube, possibly a copper tube to act as the other capacitor plate. I suspect that this capacitor was charged to a high voltage. What may well be missing from view, as I think you are suggesting, is an all important switch or secondary spark gap to pulse discharge the grenade capacitor to the load lamps. If this is the case, then as Geo suggests, the output is not safe!  :o
stupify12
Quote from: GeoFusion on July 25, 2015, 12:29:12 PM
Hi Guyz,
coil.
Cheerz
Hello.  I think everyone  are  confuse for replicating Akula and Ruslan for they have showed so many complicated electronic drivers..
As it is told by Tariel Kapanadze " it is so simple that you will laugh means you focus on the proper coil schematic diagram, also how it is wound on the coil former .
The output will still light  the bulb even the top end is not connected to anything but directly connected to the bulb, the important here is the everyone understand how this capacity( air elevated capacity and ground capacity function on this system.   Another output coil being exited by this coil which everyone call the "Antenna" but actually Tesla called this the EXTRA COIL which resonate freely away from Primary and Secondary Induction..
There are two ways to operate this device:
First, by spark gap discharge.. The design which Tesla showed with 2 series caps on the primary operates at the maximum electric wave PEAK.. The capacity and coils on this layout can work directly connected with no other extra rectifier.
Second, by Sinusoidal Wave Generator.. This design will need a spark gap " Corona Discharge" on its top end accumulative capacity so it will operate on a synchronous IN Phase to the output coils..
Remember this.
Tesla showed two drawings on how he connect the EXTRA COIL.
1st  All capacity are both on ground..
2nd  One capacity on the ground is connected the nearest turn of secondary to the primary, while the other end of the extra coil is elevated on the air as air capacity..
GEO, the output coil is connected in this manner, the nearest turn to the Antenna is connected to the Ground Capacity. The turn with the most farther from the Antenna can be directly connected to the load.. Any coils,bulbs, caps connected to the coil which serve as antenna and the other leg to the ground will be charged, will be light intensely.
That is my humble opinion.. Happy to accompany everyone to this Free Energy journey..
Remember Extra Coil means Extra Energy, Extra Resonating Energy means Free Energy..
Meow ;D
NickZ
  quote from Geo:
  "The only thing I am missing now from the First Akula Device is to know how preciesly the 28T wires are connected thru out the output
coil."
         end quote.
   What I see, is that one end of the 28 turns coil is connected to the full bridge rectifier, and the other end of the 28t coil is open, up in the air.
  Sorry for the blurry picture,  was the best I could do.
