CG Showcase of Overbalanced Wheel
Started by helloha, September 20, 2012, 09:55:52 PM
helloha
Analysing of Bessler's Clues 46.
< Improvised Method, Increase of Mass >
"Who can make a pound-weight rise as 4 ounces fall, or 4 pounds rise as 16 ounces fall"
- if there can have 1 pound (16 ounces) to 4 ounces, and 4 pounds (64 ounces) to 16 ounces
- then it can also up the value of the mass of the weighs (rolling : swinging) like
1. 1kg : 250g
2. 4kg : 1kg
3. 8kg : 2kg
4. 16kg : 4kg and on and on
- hopefully with each increase of the mass, the output efficiency of the wheel can also increase (but the increase might only be a slight figure)
- but also with each mass increase, the size (diameter/length) of wheel will also have to made changes
- relevant link related to mass changes "Shape of Rolling Weight, cylindrical vs Sphere"
http://www.overunity.com/12742/cg-showcase-of-overbalanced-wheel/msg408314/#msg408314
helloha
Analysing of Bessler's Clues 47.
< Improvised Method, More Quarters, Increase of Diameter >
"The machine's power was directly proportional to its diameter"
"If I arrange to have just one cross-bar in my machine, it revolves very slowly, just as if it can hardly turn itself at all, but, on the contrary, when I arrange several bars, pulleys and weights, the machine can revolve much faster."
- refer back to the Analysing of Bessler's Clues from topic 01 to 04
http://www.overunity.com/12742/cg-showcase-of-overbalanced-wheel/msg402305/#msg402305
- and Analysing of Bessler's Clues 13, Quarter, an alternate meaning
http://www.overunity.com/12742/cg-showcase-of-overbalanced-wheel/msg404718/#msg404718
- also Analysing of Bessler's Clues 15, Estimating the number of cross, weights, quarters....
http://www.overunity.com/12742/cg-showcase-of-overbalanced-wheel/msg405003/#msg405003
- plus Analysing of Bessler's Clues 27, number of quarters extracted using 700lbs (317kg) wheel
http://www.overunity.com/12742/cg-showcase-of-overbalanced-wheel/msg407017/#msg407017
- the above clues and analysing are inter-connected with each other (take note that the analysing are based on estimation technique, not precision)
- based on the clues, the increase of wheel's diameter will increase the machine power, together with the increase of crossbar (or cross, whichever... doesn't make much difference), end up with the result of the increase of quarters (or compartments)
- more quarters, diameter increase, so is the output efficiency of the wheel
helloha
Analysing of Bessler's Clues 48.
< Improvised Method, Built More >
"Furthermore, the machine may be of little value to the public unless it can be improved. At the moment it can lift a weight of sixty pounds, but to achieve this the pulley had to be reduced more than four times, making the lifting quite slow." - eyewitness clue
- if one wheel is weak, then built more..., learn from wind turbine
- the large scale wind industry would usually build from around hundreds to thousands of the wind turbine,
- in the case of the bessler wheel, maybe have to go for double or triple the number of builds
- pros of the wheel over the wind turbine
1. wind turbines require a wide area and spacing for the construction, whereas all the wheels can be housed inside buildings within a limited area
2. wind turbines are limited by the requirement of wind speed and wind consistency, whereas the wheels are free from these type of constraints
helloha
Analysing of Bessler's Clues 49.
< Improvised Method, Stacking and Layering >
- instead of building larger and having one large wheel to drive a generator, can try having smaller size but using 2 wheels to drive 1 generator, or
- using 3 to 4 wheels (can go up to maybe 6 to 10), to drive 1 generator
- also can implement the method of rotating the magnet and coil separately, one wheel for magnet, one for coil
- a list of relevent information on the implementation of "Stack & Layer" technqiues
1.  layout/setup for the wheels
http://www.overunity.com/12742/cg-showcase-of-overbalanced-wheel/msg364464/#msg364464
2.  layout/setup for the wheels
http://www.overunity.com/12742/cg-showcase-of-overbalanced-wheel/msg364618/#msg364618
3.  rotating magnet using dual wheels
http://www.overunity.com/12742/cg-showcase-of-overbalanced-wheel/msg380270/#msg380270
4. rotating magnet and coil using dual wheels in pair
http://www.overunity.com/12742/cg-showcase-of-overbalanced-wheel/msg380517/#msg380517
5. rotating magnet and coil using triple wheels in pair
http://www.overunity.com/12742/cg-showcase-of-overbalanced-wheel/msg384443/#msg384443
helloha
Analysing of Bessler's Clues 50.
< Improvised Method, mobile energy - Hydrogen Fuel & Battery >
"These few who saw the inside of the wheel after removing the front panel said that it had many compartments around the perimeter of the wheel, each with a shifting weight inside."
- larger diameter, greater output.... so basically the wheel  (large in size) might not be suitable for transportation purposes, eg cars, planes, small-scale ships and boats etc...
- also, if the wheel operates by weight shifting, consider the movement of a mobile vehicle when rocking, rolling, shaking etc, might disrupt the shifting of the weight, thus causing the wheel to stop.... it might be best for the wheel to be on stationary grounding
- so a possible solution is that it can go through an extra process, or steps, .... like producing the hydrogen fuel to take over the task for the mobile
- basically, the output from the wheel is used for electrolysis of water to produce hydrogen, which in turn go through the process of manufacturing the hydrogen fuel
- or, can use to charge up battery for the mobile vehicles
- info using mind-mapping "Usage and Relation between PM (if it exist) with other energy sources"
http://www.overunity.com/12742/cg-showcase-of-overbalanced-wheel/msg383124/#msg383124
