0 Members and 37 Guests are viewing this topic.
hanon
Quote from: dieter on April 03, 2014, 04:21:02 PM
I have also made tests with like poles and a pancake in between, it was very dissapointing, no voltage or any microamps.
Dieter, note that when testing like poles facing each other you have to provide two unphased signals to the electromagnets (for creating the swing back and forth of the collision plane between both fields) and you have to provide room for the movement of the magnetic lines in order to cut the induced wires. A pancake coil between two close electromagnets will not let the wire be cut by the movement of the magnetic lines.
Please read this file:
http://www.overunity.com/12794/re-inventing-the-wheel-part1-clemente_figuera-the-infinite-energy-machine/dlattach/attach/131133/
dieter
Hanon,
In my test the pancake was very small in terms of total copper mass, maybe that's why I had failed. You have to try it. Build it !!  You may be able to make tape coils with rolls of aluminum foil, and plastic foil interleaved. Tho not shure how Alu performs in induction.
Go for it!
forest
dieter
It's simple....
About Columbus egg : he did that by hit egg on tabletop damaging the tip.Another way is by fast rotating it. However the most natural way is to hold egg using two fingers and I think Figuera could thought about two equal and opposite forces : one on top and one on bottom...
Now you tell me if there is any other way to keep egg standing ?
hanon
Hi Forest,
I have to tell you that in Spanish the expression "egg of Columbus" is frequently used when something is very simple but it is difficult to guess at first. I think Figuera used this expression in this sense, not to communicate any idea about the configuration of the device. But who knows...
In your post from yesterday you commented that all coils must be in series  and the commutator will power sequentially each one. Could you draw an sketch to show this configuration? I cannot guess how 14 coils are in series and then how the Figuera´s commutator is connected to those 14 coils. Depending on these connections the magnetic field will be different. Please an sketch will be very valuable. Thanks
forest
hanon
I wish I could but commutator is black magic for me. My brain is working first on impressions and not matter how silly it looks it never failed. Flat pancake output coils in parallel makes required amplification factor by rising output current. To do that as you described exact and opposite poles are needed and output coils placed in the middle (exactly!) . Then imagine how commutator connects/disconnects coils on one side to lower field strength while the other side is stable connection (that solve strange commutator one side only while second is simple pass). Changing need to be discovered yet , maybe it is such : one coil then 2 coils then 3 coils and so on up to the final amount to make field strength then same (but opposite) as on other side , then flip sides.
The best would be to check having 4 coils only : 2+2 and trying to see how field can be moved
