0 Members and 23 Guests are viewing this topic.
NoMoreSlave
Hallo Hanon,
I got your message, and I´ll give a feedback :)
I hope that this new illustration make it clear.
there is only two coils switched on at time(every fet switch 2 coils simultaneously, because they are connected in series).
coil 1 is connected to coil6, coil 2 connected to coil7....you end up with coil6 connected to coil1 (different winding set! because each electromagnet has 2 windings)
The transistors are switches sequentially (that is the role of 4017 IC) and the frequency (speed of rotation) is set by the 555 IC.
Thanks Cadman for your help!
Regards,
NMS
hanon
Everyone,
Please comment this great idea from NoMoreSlave:
- Two 90º unphased signals are as a Sine wave and a Cosine wave.   Sine (alfa + 90º) = Cosine (alfa)
- If you place both electromagnets at right angle (perpendiculary) then the vector sum of both magnetic field vectors is a ROTATING MAGNETIC FIELD !!!
Please see this gif animation:
http://www.cbe.buffalo.edu/images/people/full_time/furlani/Image_XXZ_2.gif
NoMoreSlave, Please comment this idea a bit deeper. I think this idea has a lot of merit. People will be grateful for a further explanation of your idea in order to grasp it fine.
Quote from: NoMoreSlave on May 02, 2014, 01:38:33 PM
Sine+Cosine=Rotation
is what Figuera was doing?
stupify12
There you have it man. I congratulate you. That is I was always talking to you ever since I posted on any thread you make. Rotating Magnetic Field with out reflecting the Load to the Primary Inducing Field.
The B-Field should rotate CLOCKWISE. That is all..
There is no problem  on what NMS posted- after I have read the pdf, yes that device will work greatly on solid state switching. This works the same with the very concept of the Tesla Toroid but in another form.
The Tesla Toroid is composed of 4 wound coils, wound diametrically opposite  by 2 sets. Like this. Top + Bottom,,, Right + Left .
Each Coils has Two Magnetic Pole, so Example of the Top has North and South together with the Bottom Coil has its own North and South.
The resulting Magnetic Pole of the 2 Set Top + Bottom Coil = should be like this NORTH +NORTH and SOUTH + SOUTH on the ring perpendicular from the Two Inducing Primary Coils . I think you know how to wound this coils that it will project those magnetic poles on Two Opposing North and South . The resulting Magnetic Pole of the 2 wound coils (Top + Bottom) is a Magnetic Amplified of the Two Norths and Two South.
It is already been proven from those Bedini Motor builders that the Two The Same magnetic pole(North + North) opposing each other will Amplify the effects of the Magnetic Field.
The same goes for the Right + Left Coils.
Meow   ;D
Quote from: hanon on May 09, 2014, 07:43:56 PM
Everyone,
forest
I think Figuera found a way to decouple field from magnet .The solution ultimately must be the static magnetic flux moving in space. Rotating field is good imho , but it must be not changing in time and strength (not transformer principle but generator principle)
marathonman
Hi all,
Found something interesting on internet but man is it to expensive ......SWQO-02 DSP Quadrature Oscillator around 600 bucks. can anyone come up with anything cheaper.
NMS, thanks for the gif it really helped me in my understanding and as i see it it can be done with AC or DC 90 degrees out of phase.
Cadman, the reason i modified the pic is i don't plan on rotating it so no hole. and thanks for the info about non grain oriented iron/steel makes a lot of  sense.
i finished my two channel board construction and am waiting on heat sinks for AC nine channel board.
(off subject)
i finished construction of my no amp draw Alarm System for stand alone buildings (Works Great). draws no power until it is tripped and i have it hooked up to a Sim900 GSM auto dialer to notify(Text Message) if building is broke into......shark tank here i come....Whoo who!
