AVENGERS
Thank You for all your input, greatly appreciated. The only test equipment I have are these little cheap multi meters, not sure how to test a component like 555's or the other ic's . I did put the 12 vlt cordless drill batt. back on the individual electromagnets and found out the center core doesn't work, but the outer two are still working, I believe I burned the center primery when I experimented with magnetizing all three coils using the center coil to keep all three together long enough to let the resin set. I wound up using a bar clamp and glued them with resin and not retesting the center coil and remembering I couldn't touch it cause it was that hot. Back to the hacksaw and make another center core.
AVENGERS
RandyFL
21 May 14 / 02:50:02
Avengers......
AVENGERS!
Read the two posts above from MarathonMan and Me.......
Test your 555 and then your 4017s ..........First..........
use your cheap multimeter ( 3 volts has to be coming out of the 555 or use a resistor and a LED )
if nothing is coming out of the 555 or 4017s.....then nothing is going to come out of the transformers......
All the Best
RandyFL
hanon
Hi all,
Do you think that Figuera tried to achieve a rotating magnetic field as NoMoreSlave proposed by placing the electromagnets at right angles (perpendicularly) and excited by a Sine and a Cosine Waves (90º unphased as Figuera explained) ?  (Sine + Cosine = Rotation , see NoMoreSlave´s post #1261)
Please comment.
See these gif animations (I do not know why these gif files are static when pasted into this forum):
http://www2.seminolestate.edu/lvosbury/images/SinCosAnim4.gif
http://www.math.rutgers.edu/~ttyrrell/152_spring_14/SineCosine_animated.gif
http://www.cbe.buffalo.edu/images/people/full_time/furlani/Image_XXZ_2.gif
RandyFL
22 May 14 / 20:39:01
Hanon:
I think whatever Figuera was trying to succeed in He did. As I understand it He was a Professor in the Canary Islands. People like Nikola Tesla, Clemente Figuera and even Patrick Kelly gave/give 100 percent of their time to the betterment of humanity... Whilest people like JP Morgan, Rockefeller and George Soros took/take from the poor for the betterment of themselves...
All the Best
RandyFL
stupify12
Hanon, The rotating magnetic field which Tesla showed us is rotating inside and circling around the toroid core.
Tesla
QuoteUsually I operated quarter phase; that is, I generated
currents of 90° displacement
Tesla
QuoteI employed currents of different phase. I had in my laboratory ,permanently, a  two-phase dynamo(Generator) and could get  phases  between; that is, from two phases , 90deg  apart
The correct rotating magnetic field is the XXZ gif you have shown, 4 wound coils, divided into two primary for the 2 phase.
Quote from: hanon on May 22, 2014, 07:13:40 PM
Hi all,
Please comment.
