antijon
Little animation I made to demonstrate the flux cutting the coil
marathonman
Antijon Good to meet you to! (Welcome)
another thing to consider is the two opposing polarities with sweeping break outs as you say will be doubled, both magnetic Flux paths added together as they are compressed  as it is swept from side to side so this also effects the amper turn ratio. my two channel board will slam this side to side faster than my 9 channel would so ill hook this up to an NTE 300 watt variable tap resistor. this will allow for some fine tuning on the sweeping width.
i think this is a critical tuning step as the flux can not be brought out to far....i think it should not pass up the coil as i think the currant will momentarily drop....hummm i will watch this carefully and post findings.
marathonman
I got to thinking this morning and why can't we use a North and a South Pinch Effect core. the picture below should work if you ask me as long as the north and the south are in Unison (Correct) the output core will will be between the NN and the SS Electromagnets.
in this arrangement it could be modular and one could easily add more modules to get more output i.e. NN, SS, NN, SS, NN, SS.... get my drift..... with a core in between each one.
hanon
One small historical pearl from one of the Buforn patent's that you all will love.
INPUT: 100 Watts ( 1 Ampere @ 100 Volts )
OUTPUT: 20,000 Watts
In other paragraph of the patent, Buforn states that the output was 300 A. Therefore the final voltage delivered by the 7 induction stages in series was around 60 V, more or less 10 V per stage.
(Edited to reduce image size)
forest
hanon
Can you post link to www page where you posted all Figuera and Buforn patents with translations ?
I think it is now quite clear how they worked, in theory.  ;)
