0 Members and 59 Guests are viewing this topic.
shylo
McFarlande , Interrupt the feed of a DC motor with the secondary of a transformer , take the primary of that transformer and feed it to the primary of a second transformer, now run the secondary of that transformer to a bridge, collect the output for free.
artv
bajac
Alvaro,
Because your device goes quickly into steady state, you only need a voltmeter and an amp-meter. These meters can take turns for measuring the input and output at different times.
ALVARO_CS
yes yes
I can do that,
I can feed the dc motor (prime mover) at different power levels (Volts & amps) not only amps.
Will do it with an inductive load (dc motor at output side) in which I can check the RPM, or with a resistor across the output leads.
bajac
Quote from: ALVARO_CS on September 01, 2014, 11:11:36 AM
yes yes
I can do that,
Alavaro,
Use resistor loads only. Inductance brings issues of reactive vs active power. Thanks.
Bajac
