0 Members and 38 Guests are viewing this topic.
ignacio
Quote from: a.king21 on November 16, 2014, 09:17:00 AM
hanon: I've had a nagging doubt about the Figuera patent for a while now and it stems from a genuine misunderstanding I once had with an import export mess-up from Spain.
I mean that words have different meanings in different cultures.
Is it possible that Figuera was referring to the fact that he could get AC from DC very
simply using his method?
At that time most generating plants would be on DC, and it would cost a fortune to
convert to AC.
Figuera's device as an industrial grade DC to AC converter would have been worth millions anyway.
Could you re-examine the patent from that point of view?
-You're absolutely right, Clement F. uses the gadget to generate AC, to boot from DC. Being the only patentable.
-Tienes toda la razón, Clemente F. utiliza el cachivache para generar CA, para arrancar desde la CD. Siendo lo único patentable.
ignacio
El dibujo de energía libre es simpático
The drawing of free energy is friendly
---- Cuando genera electricidad. El relé corta la electricidad de la red.
----When generating electricity. The relay cuts the electricity network.
hanon
Hi all,
I have found this interesting explanation about defeating the counter emf  (Lenz effect) into a moving system. This is derived from the patent US5191258 by James W. German http://www.google.com/patents/US5191258 ("Electric current generator including torque reducing countermagnetic field")
http://u2.lege.net/newebmasters.com__freeenergy/external_links_from_theverylastpageoftheinternet.com/ElectromagneticDev/olafberens/olaf.htm
Maybe some skillful users as Bajac and others may find interesting to read it. Could it have any relation with Figuera rotary coil patent?
a.king: I guess you haven´t read the 1908 patent yet. Take half an hour of your time, read it, and judge for yourself. For me and for hundreds of people is crystal clear the meaning of the GENERATOR described, and patented as that,  in that document.
ignacio
Drawing legend
Can you say the differences between this picture and the others what I have exposed.
This is the design of Clement Figuera.
If you realize is a broken generator, the nuclei are not set, the drawings are Doug1
Works as ballasts!?!¿
Doug1
