gyulasun
Quote from: hanon on November 25, 2014, 04:17:15 AM
Hi all,
Important video to watch and digest:
A user in the spanish forum (link) has uploaded a video with the induced coils placed perpendiculary to the inducer electromagnets and using like poles facing each other (N--induced--N) (repulsion mode). Powered with AC from the mains.
See the results: the input is not affected when adding a load in the induced circuit.
https://www.youtube.com/watch?v=st254llePPs
Thank you very much to this user for noting this effect when testing his devices some time ago.
Hi Hanon,
Let me show you a similar principle which has been 'dormant' for some years on this forum:
http://www.overunity.com/5890/bemf-magno-motor/msg133772/#msg133772
Member DMMPOWER wrote in Reply #4:
"Yes what I have found, is when you use a permanent magnet  with a moving coil you always produce emf.
But  when you use two coil that oppose one other with the same oscillating magnetic force they will cancel each other's  BEMF."
Gyula
nelsonrochaa
Quote from: gyulasun on November 25, 2014, 07:26:31 AM
Hi Hanon,
Gyula
Hi Gyula yes that right ! , (But  when you use two coil that oppose one other with the same oscillating magnetic force they will cancel each other's  BEMF).
This technique , for me  is what the most machines that reclaim overunity use at many years. I think this part is the first stage to improve in efficiency of our circuits.
I think we should improving efficiency first,  the rest will came after , step bye step.
Its very easy to anybody test this basic circuits and configurations . But is important that people abstract of how things work conventionally and observe , compare, test ....
like   Chris Sykes say :
The old world is gone and the NEW World is here, let the transition be a relatively easy one.
(www.hyiq.org)
Very thanks for the information.
hanon
Hi Hanon,
Gyula
Hi Gyulasun,
Thank you very much for the info.
Note that the this BEMF MAGNO MOTOR is also based on poles in repulsion mode (N-N or S-S).
The concept is used for motors, not for generators, but the underlining principle should be applicable also to generators. I copy here the sketch posted in that thread.
Please replicate the experiment shown in the video posted  before and tell you insights. Thanks!!
ALVARO_CS
bajac
Quote from: Erfinder on November 25, 2014, 01:47:58 AM
With relation to the highlighted, through experimentation, I have found the sited claim is as far as I am concerned 100 percent accurate.  The phrase "high-tension current" is misleading (but is your best and only clue...) however, in my opinion it is the perfect way to describe the "current" in question, but owing this manner of phrasing, identifying the nature of the beast, and or the mechanism at play and the specific relations necessary to practice the claim is next to impossible.  I recommend you spend as much time as you feel necessary in this regard, this is one of the few ways forward
Thanks for the info. I was able to find the patent and other documents related to this case.
