0 Members and 87 Guests are viewing this topic.
Doug1
Avenger
  The two recycled coils on the outside you have marked with N and S  cw. May be the source of your own confusion. If you had taken each coil and placed them in the same orientation and supplied them with a couple volts one at a time and used a compass to mark the pole direction  on the sides of the coils and marked the leads + and - so you would have reference to both the pole directions and the corresponding connections to cause that pole direction.
  The way it is now it looks like it would cut out the center output coil all together by locking the two fields together into a single field around the outside of the former. Im not sure if just changing the wire connections of one winding would flip the poles without having to flip the coil so the leads are facing the inside leg facing down. It's hard to see how the coils are wound with regard to the layers of the coil.
I cant speak at all for your pc board ,I like analog and stay clear of Ic's at all costs because I cant make those myself.
hanon
A user in the spanish forum uploaded what, I think, is the better commutator design so far. This design uses a commutator (collector) from an old motor or generator and two static brushes touching this collector in opposite sides, one going to each serie of electromagnets. Then a rotary cylinder contains 8 resistors to emulate the Figuera´s 1908 design.
I post here this design because it could be useful for everyone.
hanon
forest
hanon
The only problem is that Figuera primary is made from two series of coils while secondary are single series (or rather connected in parallel).
Please downsize pictures
nelsonrochaa
Quote from: hanon on December 15, 2014, 08:55:07 AM
Investigating around bucking coils, following the clue given in hyiq.org,  I have found some interesting similarities between many overunity devices:
http://pvb.pavlabor.net/SE/FreeEnergy_27.01.08/%D0%A1%D1%85%D0%B5%D0%BC%D0%BE%D1%82%D0%B5%D1%85%D0%BD%D0%B8%D1%87%D0%B5%D1%81%D0%BA%D0%B8%D0%B5/Energy%20%D0%BD%D0%B5%D0%BC%D0%B5%D1%86%D0%BA%D0%B8%D0%B9%20%D0%BE%D0%B1%D0%B7%D0%BE%D1%80/magnetbeschleuniger.htm
Maybe we should add to this list the Figuera generator
Hello Hanon,
as already had occasion to say in another post,
the poles really have to be opposed North North, and thankfully you realized that this configuration is present in most circuits claiming excess energy production.
The patent Figuera we discuss here is not even 100% efficient however is of extreme importance the concept that explains figuera!
I also think that few people understand how to use the capture coil.
In my video showed that with only one turn, it was possible to capture bifilar 2Amp the generating coil, which means that the generator coil induces in each turn of a coil bibifilar 2Amp.
therefore if would add two independent loops  in parallel these same loops would capture 4A .
It is obvious that the coils being in parallel with resistance not risen,
what Figuera tells us is that we can put several independent coils and sum
the product of the catch coils.
bye
