RandyFL
27 Mar 15   05:51:05
the Laws of God don't change...
the Laws of Nature don't change...
the Laws of Man always change!
my point is this... magnetism and electricity aren't going to change just because were downsized or enlarged...
over unity isn't going to change just because we Live in Florida or India...
Patrick told (emailed ) me and stated there isn't such a thing as  " free " energy... you have to spend money to obtain the materials...you have to build it and you have to maintain it...
the circuit that's on Patrick's website I built... it works! I have 7 of the transformers in soft iron... I have electrified the soft iron with nine volts and they pick up paper clips and drop them when the electricity stops...they are electro magnets...
I have a 1 Lb. of 28 gauge magnet wire.... I can wrap 100 turns or any turns until it runs out...
I can step up or step down... or step around in a circle if you like...
I have felt the surge of pulsing electricity (magnetism) with a commercial electro magnet...
I have used a commercial miniature transformer and have seen the analog multimeter move on the lower scale of a dc range
But what I haven't seen or witnessed is 12 volts turning into 13 volts etc.............
I am getting ready to switch out 6 100 ohm 1 watt resistors to six 2 ohm 25 watt resistors and 1 50 ohm one watt resistor to 1 one ohm 25 watt resistor...
which is going to send up to 9 amps of power to ? turns of magnet wire around a FE core...with ? turns on the secondary...
so 100 turns of 28 gauge magnet wire on a primary should turn 12 volts into 12 volts on a secondary with 100 turns of magnet wire eh?
incidentally...
there is free voltage coming from the earth... :-)
All the Best
Randy
NRamaswami
I'm sorry I'm not able to understand your post. I do not understand the need for electronics and did not use it.
It is a well known thing that two different earth points will show a small voltage difference. Longer the distance between the two greater will be the voltage difference. This is not new. And is very well known.
You may please see the attached 1893 patent on producing 3 kilowatt of Electricity from Earth continuously. No electronics again needed here but wet ground is needed and all equipment is buried under the earth. At that time the device must be demonstrated to work. Look at the specific voltage and amperage given by the inventor in the patent.  Of course this is actually a part of electrochemistry combined with geomagnetism and the Figuera device is totally different.
RandyFL
that's fine...
Thank you for the info... I will study it this weekend.
I also understand your position of not using electronics... if it works for you. I on the other hand am/are committed to finishing this project with the electronics...it either will show results or not...
anyway...
have a great day/night and I will be posting results and exchanging info as they come
All the best
Randy
Doug1
Ok folks here is a nice easy site on how to make your own resisters. Scale to fit and mod as you see fit.
  http://www.cappels.org/dproj/DIY_Copper_Wire_Resitors/DIY_Copper_Wire_Resitors.html
  Funny thing this winding technique, nothing is written in stone.
RandyFL
that's nice to know in a pinch...
interestingly... Tesla and Figueras must have had their own means of resistance...
I like the fact of knowing I can get semiconductors at digi key or mouser online and egad s " radio shack ". I wonder what you do when the 555 or the 4017 s blow?
All the Best
Randy
