hanon
Quote from: NRamaswami on March 29, 2015, 09:07:18 PM
The DC power from the input was interrupted by the rotary device.
It is here that the rotary device was used to create interruptted DC.
Ramaswami,
I think you are mixing the design from the 1902 generator with the design from the 1908 generator. The 1902 works with pulsed DC ("intermittent , or alternating in sign current" as Figuera mentioned in 1902)
But the 1908 generator works with two signals. The two signals coming from the rotary conmutator. The conmutator was not delivering pulsed DC as you said. It create two continuos signals. Just see two literal quotes from Figuera 1908 patent:
" ... the commutator bars embedded in a cylinder of insulating material that does not move; but around it, and always in contact with more than one contact, rotates a brush "O" "
and, later Figuera states again:
"the brush "O" rotates around the cylinder "G" and always in contact with two of their contacts"
Therefor he was trying to get a make-before-break contact. Therefore each signal is continuous in the 1908 device.
I hope it helps
Doug1
How can it make and break if it is always in contact? Dont you think maybe it just sends the current more to one set then the other then back again by blocking the flow with more and less resistance as the brush/s travel around the circle? It's a drum by the way with the resister array wrapped around the side of the drum. The Lines of confusion show where the resistive wire connects to the contact bars that make up the commutator. Only the beginning and end of the resistance wire connect to the N and S magnets. not all those additional lines. the more sets of resistance arrays and contact sets ,the more times it will shift the field per second for a given RPM. Maybe I forgot to mention that.
forest
It's important to recall what Figuera tried to do - to move magnetic field lines instead of moving coil in space.
RandyFL
So what you're saying is Fiquera tried to obtain it...and not obtained it...or did I interpret that incorrectly...
I am learning a lot about electronics whilest trying to obtain it too.
NRamaswami
We did not use the rotary switch. Gave the power from the mains. We also built the rotary device which always touches the two adjacent points. very heavy spark comes if only one point is touched. I have even posted a video of it earlier. I'm not competent to discuss the circuit. And we did not use the circuit. Circuit appears to me to send power from top and bottom alternately and simultaneously. Total Resistance on one side is higher and lower alternately but I do not understand the circuit and cannot comment as we did not use it.
