RandyFL
Ramaswami,
You don't need a Lab to verify the results...if you have seen the results, its posted on Patrick's website and you've warned about the experimentation... so be it. If you used the " mains " to start it up...disconnect it on video and if it keeps running " overUnity ". Case over.
IMHO its a waste of time and money to pursue it any further. When I first got started building the circuit part of the figuera I realized some of the connections on Patrick's website were wrong I almost gave up half way thru it...bottom Line...I didn't and learned a lot about circuits and electricity and human behavior in the process...now there's arduinos and raspberry pi s to play with and other paths to go down....
Provide electricity to your family, friends and pass the knowledge to whoever is interested.
All the Best
Randy
ps its been a chaotic weekend and I'm behind on everything
NRamaswami
Randy;
I apologize. I do not claim to have made a self sustaining Generator as of this moment. This is demonstrated by Tariel Kapanadze only in videos posted on the net as of this moment and I do not include the Permanent magnet based devices in this list.
All I have said is that we have measured COP>8 in the device but it came only at high voltage and since is risky we stopped it. It is theoretically possible to give it to a step down transformer and give the part of the output back to the primaries. This must ensure that both the input voltage and amperage and feedback voltage and amperage are same and are given through a make before you brake kind of a switch. I felt it is risky and have avoided it.
The other option was to give the power from a UPS and then keep the UPS to be powered and recharge the batteries of the UPS from the step down transformer through suitable means. This is a reasonably safe approach. But this will require facilities and trained hands for which I do not have the money to pay nor the facilities to do at this time. Secondly what I'm saying is against the theories. When we say some thing against the theory it must be validated by an independent laboratory as correct before we can ask for Research and development support or grants or ask Universities to study this subject. Only when such a report is available others will start taking a series look at the whole project and would support it or it will die a natural death. If I do not do this, the time and money invested and knowledge gained would become a waste and will not be useful to any one. I will be seen as some one making tall claims without verification. Both replication and verification are essential for any statement to be acceptable.
It is possible that I might hold some information but it is not because of any reasons to keep things secret. We are dealing with High voltage, high amperage and low frequency electricity and it is dangerous. Tariel Kapanadze's device is a high voltage and high frequency device. High Frequency high voltage current is not dangerous as most of the time the amperage is in milliamps and the current will not penetrate the body due to skin effect and is dangerous only if you are standing on wet earth or are connected to earth.
Let me again state categorically that I have not built a self sustaining generator. I'm far far away from that stage. That I have never ever claimed. Even Tesla has never claimed it in any known patent. I do have a suspcion that he has done it in 1887 to 1889 but he does not disclose this. The only persons who have claimed or are reported to have demonstrated such devices are Daniel MaFarland Cook, Prof. Figuera, Hubbard, Hendershot, T.H. Moray and Joesph H. Cater  and Ed Gray sr and the permanent magnet based devices and (possibly Don Smith) Tariel Kapanadze in that order. The Moray device is reported to be based on radioactivity. I also suspect that beginning from Hubbard secrecy directions may have been imposed on full disclosure patent applications. Tariel Kapanadze's patent suffers from lack of sufficiency of disclosure. All I have done is to see a COP>8 effect at usable levels of power supply.  Nothing more.
Thank you for asking this question and this has enabled me to clarify things clearly.
Doug1
It's not baked till the fat lady can self run. All notable effects mentioned and aside for now.
NRamaswami
Thanks Doug
I will first replicate the performance in a reverse mode using 12 volt and 16 amps transformer and build the secondary as a step up transformer. Let me see if I can get 220 volts and higher wattage than provided. If it does then I should be able to take power from a UPS and feed the UPS from the ouput and also light lamps. Let me see if it is doable in a few weeks and if I can do it post the video
Doug1
I think your hourglass shaped core is providing a large portion of advantage to prevent flux leakage. I dont know how ells to describe the shape.
