RandyFL
Hello All,
http://www.loneoceans.com/labs/ignitioncoil/
Here's a simple car ignition coil setup to deliver a spark...
So...what you're stating is having 7 of these circuits to deliver a spark across each of the 7 transformer's air gaps...?
a.king21
NRamaswami:
Let us say you wanted to use a transformer but just had a battery.  It will not work.
You need either pulsed dc or ac.
The Ruhmkorff coil used pulsed dc.
So they used an interrupter switch similar to an old electric bell which turned the battery on and off very rapidly and automatically.
They then put a capacitor across the interrupter to decrease the sparks and at the same time increase the oscillations into the mhz range at each interrupt.
Here's a circuit diagram https://en.wikipedia.org/wiki/Induction_coil
A tank circuit creates reactive power. It is usually much higher than the input, but to get it out means you have to switch off the input. - Or so the science tell us.
No, that's not quite correct, you don't have to "switch off the input" to extract real power from that which is stored as reactive power in a tank circuit. My video demonstrations of wireless power transfer and the microQEG illustrate this quite well. What is necessary is that you don't extract real power faster than it is being replaced into the tank circuit by whatever is oscillating it. Because if you do, then the stored reactive power will collapse until it's replaced by the source.
a.king21
Quote from: TinselKoala on May 19, 2015, 02:28:55 AM
So how much power did you extract vs input power?
ps I stand corrected.
RandyFL
but....
How much power do you need to jump the air gap?
the BDX53 s provide up to 9 amps and the 2N3055 s provide up to 35 amps
100 watts or 400 watts
