0 Members and 18 Guests are viewing this topic.
I added a second pot and a couple lines of code to kEhYo77's program sketch above to allow varying the phase difference "on the fly" without having to reprogram.
The code doesn't actually put out sine waves, but rather cycles the PWM outputs on pins 3 and 11 from 0 to 100 percent duty cycle and back, on a sinusoidal time frame. The PWM voltage is constant but the duty cycle varies, so after applying the low-pass filter the voltage signal should be approximately sinusoidal.
NRamaswami
Dear All:
I saw the posts of Hanon..Most of them have quit after the identical poles did not provide the results. In Tamil We have some Proverbs..
Efforts Never Fail.. Even if your efforts have not succeeded they have taught you what will not work and what must be avoided.
Efforts will lead to success. Not taking any efforts will not get you any where.
Even if God cannot give the results, efforts will give results to the extent your body aches from the effort you have put in for the cause.
In English it is simply stated as Winners Never Quit and Quitters never win..We will make an attempt avoiding the complex rotary switch and the resistor array.
I will try to see if I can get hold a 12 volts and 16 amps transformer or a Variac and will use the Full wave Diode Bridge so that the one way positive current is sent to the earth as indicated in my earlier post.
I will arrange a few small size devices to be built. We are set to buy a lot of iron for a different project and from the old stock I can manage a few large primary solenoids and we will see  if it works as predicted. However Lower voltage and amperage is used so that I can follow ampere turns and small coils can be used for the primary cores and we will check if the secondary cores are able to produce  more than 200 watts at the input. It will be a small scaled down set up that will show that with a small input of about 200 watts it is possible to get about 500 to 600 watts. Let us see if the Lenz law free effect comes and whether the small transformer is able to do its intended part. It will be a small set up and so do not expect a lot of power to come. We will have about 7 cores each providing about 40 volts and so the output would reach 280 volts  in a 4 sq mm wire. Let us see what is the output wattage. We will put a small 1 amp fuse on the transformer so that more than 220 watts cannot enter the systerm through the transformer. Let us see within a week if this works or not..
It is an extremely simple system. Made unnecessarily complicated. I of course will not run the self sustaining part.
JohnMiller
I tried to run the program above but get errer mesages.  I use the Arduino IDE - just new installed.
Do I need any additional library or .h file. I am no programmer and feel very disabled.
Quote from: JohnMiller on June 23, 2015, 05:05:59 PM
What are the error messages you are getting? The code compiled and ran for me with no problems using a genuine Uno.
You should be able to copy-paste it into the IDE window, and verify, save and run without any additional library or .h files, the IDE is supposed to gather those together for you automatically if it's installed correctly.
What version of the Arduino board are you using? Can you get any of the example sketches in the IDE to run? Look in File>Examples>01.Basics>Blink, see if you can get that Blink sketch to compile and run. Under Tools>Board, make sure you have the right type of Arduino selected that matches your board.
RandyFL
Quote from: kEhYo77 on June 22, 2015, 04:41:14 PM
A repost.
Hello KEhYo77,
I re watched the video that you made showing your version on the Figuera...I am sure you have watched " Woopy's version " using the arduino... " He stated that the ghost trace was for free "... A. would you agree with that statement. B. Did you get the same results...or did you get different results. The video that you made was two years ago... C. Have you made any more experiments on your apparatus... Its been stated here, in the forum, that by using the arduino you can get a stronger current... D. Do you agree with that statement... E. have you used a stronger current F. Do you plan to use a stronger current... Lastly what do you consider wrong with the figuera on the Kelly website... 1. Is it missing some secret " ingredient " that He wasn't divulging or died too soon to reveal...and where did you get that ball cap............... :) I thank you for your answers in advance....and get back to work on the Figuera! ;)
All the Best
