0 Members and 50 Guests are viewing this topic.
NRamaswami
Dear All:
I must warn every one about one unknown thing about the Figuera or Ramaswami devices. They do work. They are capable of creating higher output than input. But there is a problem
In Natural Bar magnets the waves flow out of the north pole and move towards the south pole and then they move inside the magnet from the south pole to the north pole. In a permanent magnet this process continues all the time.
In the Figuera and Ramaswami devices three combinations are possible.
a. input Voltage division.
b. input Voltage maintenance
C. Voltage multiplication in secondary by giving the primary in parallel. The output in C is 4 times the output in a. The input in C be brought down than the input in C if we use many coils in the multifilar coils say about 12filar coils due to increasing inductive impedance and we can effectively bring down the input wattage to about 110 watts. The output is far higher than that for the magnetic field strength is not diminished.
I tried to post many photos of the earlier experiments (the 2013 experiments were deleted but some of them remain and some members of the forum have received all the photos already). But there are limits on posting here.
Please see the strucutre of one of the modules where voltage division occurs. You can see that 10x200 lamps are able to light up. The no load voltage was 66 volts and after ten lamps were lit it was 33 volts and 6 amps. The input wattage was 600 watts approximately. If you look at the two primary coils carefully you would find that there are secondaries there and these secondaries are not connected and not closed or shorted but kept open with insulated ends. So we had COP=0.32 or 0.33 here. What is the deal nothing would be the first thought.
But if you keep adding the modules the primary input keeps going down in AC due to increasng inductive impedance. The magnetic field intensity is not altered and we can add more wires to maintain the magnetic field intensity of the primaries.  The secondary output keeps increasing due to the fact that the secondary voltage keeps increasng. This however happens in AC only when high voltage is applied. Alternatively we can use 440 volt Ac input and use a single module to increase the output of the secondary.
In pulsed DC high voltage cannot be applied. Pulsed DC does not feel the inductive impedance of the AC but only looks at the total resistance of the coils. It does not care whether the coils are multifilar coils are simple helical coils. High ohmic resistance must be provided before the coils if we are to use pulsed DC or DC or undulated DC. The coils shown by Figuera are high ohmic coils. In addition resistors can be placed between N1 and N2 and N2 and N3 and so on so that the current on N1 is maximum and current on N7 is minium. The Input is given at N1 and S7. So current on S7 is maximum and minimum at S1. To compensate for this we need to use increasing number of wires and turns in the lower current coils. This produces a situation where one of the coils has high current and the other one has high voltage. When the coils move towards the center the back emf due to N coil goes to the easiest path of receding current of S coil and the backemf of the S coil goes to the recedeing current of N coil. Hence there is no Lenz effect in the device.
In the Figuera and Ramaswami Devices there is one problem. We have conducted more than 100 experiments in the last 27 months. Every time we do these experiments we will feel very tired. Whether it is a young and energetic teenager or well built drivers assisting me or myself we will all feel tired. very tired.
In the Figuera device there is a problem. normally in a bar magnet the waves move out of the north pole and then move towards the south pole and from the south pole to north pole they move inside the magnet. This continues non stop.
But in these devices We do some thing against nature. The two primaries are larger and the way the coils are wound and the core is shaped
(central one is about half the diameter and half the length or 2/3d diameter and 2/3rd length of one primary) So what we are doing is we are compressing the magnetic field in the center and the center coil which is the output coil has far higher magnetic field strength than the outer coils. This is especially very high when the option C for sending current in parallel is used. When this option is used we compress the magnetic field in the center and then decompress it. Result is waves do not flow like in the normal way in the bar magnet.
I have measured about 4.1 Tesla range magnetic field strength in the central magnet and the magnet simply attracts any current carrying wire even at a distance of 6 inches to 8 inches from it towards it.
I strongly suspect that the central magnet emits some harmful radiations because of this unnatural movement of the magnetic fields. I'm not a scientist but I can confirm that all of us would feel exhausted after doing these experiments.
well when I connected the secondaries under the primary we had 351 volts and when it was connected to earth we did not get the output expected. It was then advised to me that I should put up two new earth points and then check again. One of my mentors who is a distinguished Scientist in Germany was satisfied and he assured me that you put two new earth points and you will be surprised. It would be about 351 volts and about 12 to 14 amps and would be in excess of input and this is known to me. However when we do it again the central magnet becomes very powerful and makes a very loud noise. indicating total saturation. Last time we did this the person who arranged and tested died within 3 months of the test. he was expecting a short life span any way but why take a risk.
The experiments in 2013 were not witnessed by a person who was present in my office at the time the experiment was done. He did not directly measure any thing. But he clearly indicated that some thing happens to the material inside due to this high saturation. I have used soft iron rods. They are magnetized when current is given and demagnetized when current is removed. However 10% of the rods have become magnetic rods. We have to check if there is any carbon content in these rods.
Now let me clearly tell you that we have all suffered. I'm just a shade of what I was 3 years back healthwise. My joints have repeatedly swelled and I have difficulty even walking for 20 to 25 minutes at a stretch. We do not know that this unnatural concentration of magnetism in the center and compressing and decompressing it has produced any harmful rays. We simply do not know but what we know is every one who participated has health issues.
May be I'm very timid and very frightened. But I can tell you that we all have had health problems.
The photos are attached. They were privately shared with some other friends already. The device works as claimed. But the problem is that the  center coil is far more saturated than the outer coils and has magnetic vortex pulling every thing towards it.
The photos of 2013 experiments were deleted by us.  They are not available. Some were deleted on purpose and some were in a digital camera that has gone. We do not know how to recoever it. We have also placed a lot of neodymium magnets near that camera and so I do not think any thing would be there really.
This is a suppressed technology and we wanted to make sure that it reaches as many people as possible in as many different places as possible. So I have used this forum to post the information so a lot of people will know. But unless the issue of suspected harmful radiation is solved doing this device is not advisable.
In addition to all this it is very expensive to build this device. There should be a lot of iron to reduce the saturation and very thick wires should be used in the secondary (about 15 sq mm wires ideally) but the voltage per secondary coil should be kept to a very low level of about 15 to 30 volts per secondary in the center so that the combined secondary has about 220 to 240 volts and high current.
The last photo dated 22-08-2015 shows an attempted replication of low voltage Figuera device with two modules. Pulsed DC was used and the input was given at the two points. Because we have not put the resistance after the transformer there was very little input of current and the attemped device did not work.
Every one associated with the experiments have suffered health problems. So when you do this please be careful. I suspect that the central magnet which reaches high saturation gives out some inimical waves but how do I find it out? All I can tell you is that we have all suffered.
This is not cheap. Each experiment cost me in labour costs alone $100 here. It requires helpers to do these coils and wind the coils. There are many other photos but they are not needed as the small central coil of a voltage dividing primary of one of the modules is able to light up 10x200 watts lamps.
May be I'm very timid and frightened. But I wish every one attempting to do this device all the Best of luck and all success. But please be careful about the radiations and remember that we are doing some thing that is against nature in this device.
marathonman
Doug1 i will read the Tesla patent.....and thank you as i forgot Tesla has done about everything. my system will work but less parts the better.
NRamaswami  i an not trying to be disrespectful this time but this is a thread for Re: Re-Inventing The Wheel-Part1-Clemente_Figuera-THE INFINITE ENERGY MACHINE not some NRamaswami bull shit.....so if you have to ramble on like some very lonely lunatic with nothing to do PLEASE GET YOUR OWN THREAD. matter of fact I BEG OF YOU to get your own thread and while your at it please contact Patrick and have him remove all Reference to this thread about your back yard devise........ THANK YOU!
NOW ! Back to business with "FIGUERAS DEVICE" the windings are CW-CCW-CW-CCW-CW-CCW...ect as i forgot to mention that but i'm sure from the drawings that you got that.
as for my observation that the output core could be a 2"x 2"x 2" cube solid iron or laminate and the north and south electromagnets are 2" x 2" x 4". i will be using 18 awg for my electromagnets and 10 awg square wire for my output cores as i found a low quantity supplier for that.
again i can not Emphasis  enough as to the wiring of the input cores. please study my previous post picture and realize how true and important the proper wiring is to the operation of the figueras devise. his patent was only a guide line and was drawn to throw off big bankers.
i will post later a picture of a early 1900 rotating dynamo and you can observe the proper wiring your self....."THIS IS THE ONLY WAY" it can be wired.
FIGUERAS ROCK'S !
hanon
Marathonman,
Please be respectful with everyone. NRamaswami has been sharing with us all his findings using the basic Figuera configuration :
ELECTROMAGNET--COIL--ELECTROMAGNET
He is following the foundation settled by Figuera in his 1902, the patent no. 30378, and we should be glad for receiving such good news. He finally has got measurement while powering many lamps. These are really great news!!  As you I stopped doing test but now I am thinking about restaring again.
Marathonman, your configuration with powering alternative each sequential electromagnet in the series is similar -as far as the electromagnets side- to the configuration shown in post #2523, on page 169,   where the polarity is alterned N-S-N -...in each serie with the advantage that with this configuration you may close the magnetic circuit between each group and therefore resuce the input consumption. The difference of you proposal with this configuration is the orientation of your induced intermediate coil which is transversal to the electromagnet axis. This is the difference in essence. Take into consideration that in any dynamo there is motion and thus the wires can be transversed because with the motion you get the wires cut by the magnetic lines. I will like to grasp deeper your proposal with the transverse induce coil.
This a great day: we have some great experimental results and also some new proposals  :) :)
core
This thread is infected with people who build nothing and have nothing. My personal favorite are the one's who boldly state "THIS IS MY LAST POST......... I SWEAR IT".... and then naturally return to continue posting  ???
Since its so EZ to claim success then I claim, on this day, that I, Member CORE have a working device. We now have a Figuera device and a Core Device.
Really?.... Are we to believe that a person who can't figure out how to resize a picture to 800 x 600 can figure out Figuera????
Sad day...... NRamaswami pay close attention here THIS IS HOW ITS DONE.
This is my last post, ......you lose
That's right I am taking my ball and leaving
- Core
