0 Members and 58 Guests are viewing this topic.
marathonman
PRINCIPLE OF THE INVENTION
Considering carefully what happens in a dynamo in motion, we see that the coil turns of the induction circuit
approach and move away from the magnetic center of the magnets or electromagnets, and those turns, while
spinning, pass through sections of the magnetic field of different magnetic strengths, because, while the
maximum magnetic strength is in the center of the core of each electromagnet, this action weakens as the
induction coil moves away from the center of the electromagnet, only to increase again when it is approaching the
center of another electromagnet with opposite sign to the first one.
Because we all know that the effects seen when a closed circuit approaches and moves away from a magnetic
center are the same as when the circuit is motionless and the magnetic field increased and decreased in intensity,
since any variation of the magnetic flow traversing a circuit produces an induced electrical current. Then,
consideration was given to the possibility of building a machine which would work, based, not on the principle of
movement as current dynamos do, but based on the principle of increasing and decreasing the strength of the
magnetic field, or the strength of the electrical current which produces it.
this statement taken Directly from the Patent tells me i am right on track and no one will tell me other wise.
Doug1
Quote from Tesla 1895
"That is the trouble with many inventors; they lack patience. They lack the willingness to work a thing out slowly and clearly and sharply in their mind, so that they can actually 'feel it work.' They want to try their first idea right off; and the result is they use up lots of money and lots of good material, only to find eventually that they are working in the wrong direction. We all make mistakes, and it is better to make them before we begin."
  The sense of urgency is false if it results in continued failure. Is that not how we got here in the first place?
shadow119g
 marathonman,
I really want your discovery to work. I have a feeling that the solution to this device could
be something as simple as your suggestion.
I seems there couldn't be some weird secret from the time when this discovery was made.
I don't know, but I wish you the best of luck.
Also, I feel like a lot of people don't want someone other that themselves to find the answer.
Shadow 119g
DreamThinkBuild
Hi Marathonman,
In patent 30378 Figuera shows an alternate version which is a little abstracted by the mechanical elements.
Quote"...two sets of four excitatory electromagnets in each, and the induced circuit is marked by a thick line of reddish ink, being this way the general arrangement of the appliance, but meaning that you can put more or less electromagnets and in another form or grouping."
A 2001 Canadian patent CA2357550 by Bud T. Johnson is the closest to this setup.
CA2357550 - Electrical generator - solid state configuration
https://www.google.com/patents/CA2357550A1
I have to agree that idea sounds simple by Figuera's description it is pretty much lock an AC generator coil at the 90 degree mark and just alternate the flux cutting through the center with electromagnets.
Quote"...Leaving still both the induced circuit and the core, it is essential that lines of forces to be born and die, or being removed, which is achieved by making the excitatory current intermittent or alternating in sign."
marathonman
I thank you for the confidence.
apparently some people are having a hard time visualizing what is going on in figueras device, maybe this pic will clear it up.
north and south coils working together.
shadow119g your last sentence said it all.
