0 Members and 27 Guests are viewing this topic.
marathonman
In my humble opinion this Patent should not of been issued as it infringes on Figueras Patent in which is in public domain as those Patent are expired but i have no expertise in that field.
Figueras device is  more efficient than this device as he used two cores instead of one,  eliminating Hysteresis in the inducers completely and by using pure Iron output core the Hysteresis their is almost non existent.
but all in all this is a good device and it does supports my theory.
Doug1
You have to file in each country you want to secure your rights in, which is pointless if you do not have the finances to higher attorneys in all those places in the event of having take legal action. Patents do not come with free legal support they just give you leg to stand on as proof of ownership. Thats only worth about 50 cents if you take into consideration the governments can decide to over ride your rights for number of reasons. You wont know that or what those reasons are until it happens. Kind of like playing poker with someone who is making up the rules as they go along so they will always win and you will always lose. It always comes down to money. Just another reason the system has to be forced into total collapse.
Doug1
Marathonman
I found you a good and simple tool to use which will most likely help you in the end.
http://hyperphysics.phy-astr.gsu.edu/hbase/magnetic/emfchb.html#c3
You may have to play around with it for while to figure out how your model is going to function. It will surely determine if or if not your confusing the motion of the field"s" with the position of magnets.
  This tool can be used by itself to make right all the silly notions which will never work if the desired result is a self runner.
marathonman
The only tool i found on that site is a solenoid magnetic field calc tool and that's it. i have already been using a solenoid tool from another site. besides i can't get it to work. if you are referring to another tool on that site i am lost.
antijon
Doug1, induction really is amazing. That tool is what sparked my curiosity when I was a kid. It's crazy to think that the induced current will still flow even if the coil is already powered.  ;D
Norman, I have tried my ideas. Mainly the three coils, will poles all vertical, or parallel with each other. I think it's the same general design as the one Bajac was working on. But I don't have the skill to make a commutator, so I used AC with a capacitor to make 2 phase. I figured that would be faux pas, so I didn't mention the results. I'm only dealing with 12V input, but the max output I got was 91V, which exceeded the supposed output for the turns ratio, which should have been 60V.
I think one of the problems with this particular setup is that the "exciter" induction can bypass the coil. When loaded the output was only .5W. The image might be an improvement to this design, by adding an airgap to prevent the exciters from bypassing the coil. Really, with a larger coil, higher inductance, and properly wound exciters, this design may work. Bajac may have better success.
About this perpendicular coil patent, I have doubts that it works. It looks like he has the electromagnets wired in parallel, and all the fields in the same direction. This could be powered by AC instead of a DC switching circuit, but I guess he included that for the high current pulse and lack of reactance. Saying that this resembles a generator doesn't mean anything guys, because when the armature is at 90 degress in a generator, no current is produced.
The patent is also not like a dynamo, Gramme ring, or any other generator. It has a north on one side, and a south on one side, and if the coil were moving up and down, would produce equal and opposite currents which cancel... or simply no current at all. But I can see why it should work being static.
