0 Members and 97 Guests are viewing this topic.
hanon
Quote from: hanon on August 13, 2013, 04:03:45 AM
Hi all,
This is a post to correct some errors in the circuit that I posted in post #106 in the 15th of May. Please see the attached file with the correct circuit to implement two unphased signals as defined in the 1908 Figuera´s patent.
Hi all,
I have been testing the circuit disclosed in post #185 and previously in post #106 to create the two unphased signal required in the 1908 patent. I have found a mistake because pin No. 3 in the second CD4017 counter must not be used. Therefore this post correct post No. 185 and 106. I attach this file in pdf format and in jpg format.
Regards and good luck to all replicators!!
bajac
Ariovaldo,
I wanted to ask you about the air gaps. Are you providing air gaps to the iron core of the 25KVA transformer? If you do not provide the air gaps, there will be cross talking between the two primary coils. In other words, the magnetic filed of a primary coil will reach the other primary coil moving through the secondary coil completely, and as a result, there will no be induced voltage in the secondary coil.
Thanks,
Bajac
ariovaldo
Quote from: bajac on September 23, 2013, 06:09:30 PM
Ariovaldo,
Thanks,
Bajac
The 25 kva transformer is just to play. My intention is to build 6 small transformers with very smal air gap, to avoid the " normal" transformer  function...
I will sketch to show you..
Cheers
Schiko
Hi
@Hanon... maybe you interested in using my scheme, I added one more step, and a correction circuit of the peak of the waveform, (R4) when going through step 1 and step 9 giving the space of two steps as in the original patent from 1908 to soften the waveform... disregard the part they are only transistor to generate the waveform for my setup.
And thanks again for everything!!!
ariovaldo
Quote from: Schiko on September 24, 2013, 01:20:22 AM
Hi
Good!!!! 8)
