marathonman
To tell you the truth i don't know why i am even Acknowledging your crazy post but hear it goes.
for one,  the max Gauss's of pure Iron is @ 2.15 to 2.2 Tesla's and if someone did their home work they would know this and wouldn't wind up sick with their feet the size of Elephant's feet from all the RF damage radiating from a poorly designed device you call a success. if you ever want to open up a hot dog stand your device would be great Microwave emitter to heat up the dogs. just please keep your feet and hands away.
two,  is i have both those books and are garbage if you ask me, a total waste of money. all he does is speculate and has proven zilch or even built zilch. basically another Tom Bearden or Peter Lindemann. all these people do is sell books and get rich off of other people's ignorance and i for one not knowing at the time fell into this trap.
as for the outrages currant 300 amps that was posted is total BS. all a person needs is 41.6 amps @ 480 volts = 20,000 watts.
if that is taken through a 480-240/120 split Phase transformer everything will be ok as far as i know. even that is way beyond what the average household needs. who the heck needs 300 amps.
and last you have to realize we are NOT working on your RF device, we are working on 1908 Figuera Patent. it as we all understand it is NN design.... or SS if your into that kind of stuff. ha ha ha
NRamaswami
Marathonman:
1. It was taken from some University website and extrapolated to Excel by us. You can do some search and find the University values that tested iron up to 10-20 Teslas of various types of iron.
2. The Elephantine legs are gone. Turns out that apart from all this I was working for 20 hours a day and sitting before the computer in my chair has caused the body fluids to store in the legs. Not due to the device. No other person who experimented suffered this and only mine. They all kept moving and had no ill effects. I had to sleep for 10 to 12 hours a day, steam the legs and do a 30 minute walk in the beack a day without shoes on bare feet ( we can do it in our hot country in the beach) and well the elephantine legs are gone. Turns out that I need to do a lot of yoga exercises to tone up the entire body especially the legs as they have become weak.
3. I have no comments to make on NN or NS. I have made both of them to work and I'm aware that for SN-NS-SN kind of thing to work you need a different geometry and the straight line does not permit it. If you go back to the earlier pages there are people admitting that identical poles produce zero volts.
4. I have done experiments and no theories. Cater is reported to have built a device in 1971 and applied for patent and was prohibited under National Security laws and then he kind of became a rebel. His information to the most part is inaccurate and misleading but he provides hints as to how certain things can be done. If we expect these people to disclose fully what they have done and how they have done and try to replicate it we will end up with failures. If we understand the principles we can succeed.
5. I do not know any thing about Tom Beardon but he uses a permanent magnet in the middle of the MEG if I'm correct to increase the magnetic field strength and prevents the collapsing of the magnetic field strength to zero. I look at the principles and try to understand them and not try to copy to the dot. I have to agree that most information given is misleading and inaccurate if taken accurately.
6. I would agree with you on the need to use a lower amperage output but we need to see what is given in the patent. If the patent says 100 volts and 1 amp input and it is acceptable to you, then why the 300 amp output is not acceptable is not clear to me. Back in the 1900s DC was the most used one and high amp DC required thick wires and the wires that were available were only like that intended to carry DC to short distances at considerable lossses.
Any way I'm not able to continue to post here as frequently as I used to. And I'm sorry about it.
how2
The  simulations which were posted on this page,  have been deleted.
But, if simulators could possibly produce overunity,  you could simulate 2 of the 3 main components,  the primary-coils-inducing-the-central-secondary-coils,   and the resistor-coil,   but not the rotating-switch-unit.
(  even if simulators are not good enough to produce overunity,  maybe there is a simulator which has a  'different-view' function which creates an animated diagram that shows what is going on in  the primary-coils-inducing-the-central-secondary-coils,   and the resistor-coil ,   to make it more understandable to those of us much less knowledgeable in electrical-circuits  )
   The recent posters have ruled out the possibility that the  rotating-switch-unit  could possibly have had any similar effect to a  rotating-tesla-switch  http://panaceatech.org/Tesla%20Switch.pdf  ,  they have the required knowledge in this area .
You could just build and test  2 of the 3 main components, separately,  and using less coils,  to try and detect any overunity.
_________________
  What rotates the  rotating-switch-unit,  I cannot see a motor mentioned in the device,  or even any permanent-magnets  to cause a homopolar-motor  effect .
_________________
QuoteYou should read up on a perfect current source, which is impossible, but still, as load resistance increases, voltage increases, and so does power out. All you need is a source of current with zero internal resistance.
The closest thing could be  a  Persistent-Current ( https://en.wikipedia.org/wiki/Persistent_current ) powering an  Electric-Motor( made 'Entirely' out of superconducting material ),  so that all of the electrical-conducting material( wiring and motor etc )  used in this idea is entirely made out of superconducting-material,  so that there would be no energy lost through heat.
    And maybe, this idea could be run in a vacuum .
(  Normal electric-motors only lose energy through heat,  they waste no energy in generating the electromagnetic-fields to make the motor spin,  although,  the electrical-current changes the winding's into temporary-magnets,  so I assume that those winding's could be considered a load because they are not yet the temporary-magnets that the electrical-current turns them into,  but I am not sure  )
(  Some time ago I noticed that a  Persistent-Current energy-storage( or was it generating ) device had already been built, for some specific application,  but I can no longer find that )
Even More Off Topic
I once discovered that by placing a permanent-magnet right up next to an electric-motor,  that the motor  sped up very-very significantly,  I assume what happened is that the permanent-magnet increased the magnetic strength of the permanent-magnets already present in the motor,  I replicated it a couple of times,   and then later on,  I actually discovered that someone on the internet had discovered the same thing,   but only 1 other person,  but the replication by the other person is too hard to find .
citfta
Adding a magnet to the outside of a PM motor has been known to several of us on the Energetic Forum for at least the last couple of years.  I just recently discovered that it also works with a universal type motor if that motor is run on DC.  What was also interesting is that a large ceramic magnet worked much better than a small neo magnet.  I don't have a way to prove this but I think the neo magnet may be over saturating the laminations of the motor.  Please don't tell Milehigh about this as he is convinced magnets can't do work so therefore what we have seen must not be possible.
hanon
Antijon, why did you delete your posts???
How2, why do you make posts off topic and even more off topic? You are welcome to create a new thread about the tesla switch in particular.
Click on the World Globe Sketch located under my nickname to go a website full of info.
