0 Members and 55 Guests are viewing this topic.
bajac
Schiko,
Please, refer to the post#58 of this thread. In the post, I posted the graphs of the voltages and currents. The waveform should be more triangular like step triangle. But, it is not the same condition when the load is pure resistive than when is an electromagnet. You will need to do a kind of impedance matching between the seven resistors and the coils to get the maximum AC/DC ratio of the input voltages.
Noticed that the air gaps shown in your pictures are too big.
Bajac
Schiko
Quote from: bajac on September 27, 2013, 12:30:49 PM
Schiko,
Bajac
Hi bajac
I already thanked you hanon and others for everything they taught us, once again thank you!
I subscribe to the forum (reinventing the wheel) from the beginning and learned all that was said, I think, so do not worry about me I've been through that phase.
I have experienced much the device and was developed over time, but remember, I adopted another path that is: "high frequency between 400Hz and 40KHz",  "regenerate 12V", "with much more power on output that in the input" and "self-run working"...
I'm asking you if you've built your H-bridge because I've finished my, but I don't have many resources to mount the magnetic Assembly like yours, that's why I live bothering you with this question, sorry about that, I would very much like to see a set like your working with H-bridge and see if you can COP>1, in my setup I could only get 4 small transformers, worked fine but not exceed of 100% efficiency.  :-[
I get an almost perfect sine wave output for perhaps the difference from my system to its like I said I can control all parameters of the input signal.
And the pictures posted are old when I started working with this system Figuera 's, these photos are just for show "Ariovaldo" there are other more practical ways to build the magnetic Assembly and that work well within the same principle.
You know in the picture with ferrite core, 12V input and output almost 30V if I don't back off my cores 12V lamp would burn, so...
In fact I think that replicate this patent literally or as many have posted here won't be able to COP>1, this is the "my thinking" and I don't own the truth and I'm here to learn.
"I want to see the snake biting its own tail" auto-run is the word the rest doesn't matter!  8)
cheers!!!
ariovaldo
I don't have the material to replicate the patent as I would like too, but I do 2 set transformer core 280 mm to 100 mm and I will play with them. I ordered some 14 AWG magnetic wire that will be here next week.
Have a great weekend.
Schiko
Quote from: ariovaldo on September 27, 2013, 04:47:13 PM
Nice cores...
Cheers!!!
bajac
@ Schiko,
I want to congratulate you for your efforts. I think you are in the correct path.
You may ask as many questions as you like. The nice thing about a forum is that you can get different answers and views. That makes it more exciting!!
On the other hand, why do you think the Figuera's device would not work? Did you replicate it? If yes, could you post the device that you did your test?
I cannot say the same. I tested the device and the results were like nothing I had experienced before. I was telling Hanon that the short circuit test soldered the secondary leads together. I had to shutdown the device to cut the leads. I was not able to measure the short circuit current because I did not have an equipment with such a high current range. But amazingly, the primary current did not change, it just measured about 1.3A DC before and after the short circuit condition. During the short circuit condition, the transformer started vibrating and produced a loud Humming sound. I am so disappointed for not following the teachings of that setting. That is why I am rebuilding the tower to match the coil turns of that setting.
@Ariovaldo,
That core looks promising! It has good dimensions for a first trial.
Thanks,
Bajac
