a.king21
Resonance? It depends on which definition. EE definition you need a capacitor ie tank circuit.
Tesla definition is longitude  wave. ie radiant energy. I don't remember Figuera  mentioning resonance or capacitors.
You amplify current by using step down transformer. Of course you lose voltage so power stays the same minus losses in the circuit.
ariovaldo
As i said in one of my posts, I have 2 sets of transformer core 280 mm to 100 mm and I had the windings done in the primaries of one set. Is 360 turns of 14 AWG aluminum magnetic wire. My plan this week is to test several configurations. As you can see, the sets are composed of 2 "C" and one "I". In the picture number 15, I put a small insulated plate to make a "gap" between the elements.
Any suggestions for test?
Ari
ariovaldo
Quote from: a.king21 on September 30, 2013, 08:15:39 AM
That is the classical knowledge! The transformer that you can see in the picture that I posted minutes ago, was tested with 4 turns of thick wire in the secondary, and believe me, the current amplification very high.
Thinking out of the box, what can we do speed up the large flow of electrons in this case, without use to much energy?
a.king21
Quote from: ariovaldo on September 30, 2013, 08:34:01 AM
Well... you are starting to sound like the Barbosa-Leal patent from Brazil.
http://www.free-energy-info.tuks.nl/Chapt3.html
about 1/3 rd of the way in the document.
forest
Good path.
You already know the answer I'm sure ;-) Sometimes the answer is very confusing....  The simplest way to rise amperage without rising voltage is ....by having the second power source adding electrons at the same voltage level......  ::)
C'mon...you already saw that picture.... that's how noise is generated to hide the truth by mixing real info with garbage....
If you can take second battery and attach in parallel to the power source at the same voltage then you have the simplest way to rise amperage without rising voltage. Now... the "magic" is to find a way how to do this with AC and 2 frequencies .
That is the special case Steven Mark said "another time" and you already saw the picture explaining it.....just find a picture with two signals drawn by red pen....the noise level is astonishing....
