forest
He was not the single one. Earl Amman run his house from output of his generator and many others also...
http://rexresearch.com/feg/feg1.htm
NoyPi
@forest,
you mean to say that CF device can capture magnetic field lines of the earth? IF EM coil orientation was NN, we can attract fields from South Pole?.. Hmmmm......
NRamaswami
@Forest, Massive..Thanks for the kind words.
It really amazes me that in this forum where people are supposed to do experiments and share their results with an open mind. We are not getting that kind of info unfortunately.
Electricity comes in Electromagnetism by oscillating or vibrating a magnet core and coils are wound around the magnetic core. It simply means that as long as the magnetic core is not static but vibrating or oscillating electricity is going to be produced. Whether that Electricity comes from Sun, Moon, Mars, Jupiter or Earth or Atmosphere we really do not know.
Every atom has a North Pole that contains a part of south Pole and a South Pole that contains a part of North Pole. What we see as Magnetic core is only a conglomeration of billions and billions of Magentic core atmos or molecules. No one knows where the current is coming from and how it is produced. When a conductor is subjected to time varying magnetic field, electricity is induced in the conductor is the Rule. We need not worry as long as it comes.
Open air cores work with high frequency currents. They work very well if the insulation is thicker. It beats me how thickness of insulator plays a role in electrical output. I do not understand it but that is the observation consistent observation made by me and made by others.
Majority of information about these coils are to put it mildly misleading.
When Wright Brothers wanted to fly an airplane they were considered crazy. Sending a satellite to orbit the Earth was considered impossible. Humanity has done it and once the imaginary impossibility is broken many fast developments have taken place in all fields.
Probably I had been chosen to give this information for I'm in no way connected with science and my growth does not depend on what I write whether it is consistent or not consistent with theories. I really do not know why a few people from other countries sent funds to me and asked me to continue with the Research. It again beats me why Patrick took so much of time to teach me through emails.
In 1871 McFarland Cook made the self oscillating device. But the patent provides patently partial information. It seems to be subtantially edited. I feel that I can just use  coils of wire alone and do the device but it is risky. So we need to provide for the safety features.
So this is the real task..
When a conductor is subjected to time varying magnetic field, electricity is induced in the conductor is the Rule. We need not worry as long as it is oscillated continuously. Ultra fast switch on and switch off circuits with capacitors or coils arranged as capacitors must then store the energy for continuous vibrations and the only thing needed is to start it.
I'm really sorry to say that not many here appear to do real experiments or make observations and share results. I do. This is the reason for my confidence.
hanon
A curious quote from the 1914 patent  (page 28 in the pdf document with its translation)
"...and further more, as the current passes to the magnetic field and
returns from it by the two inlet and outlet ends of the resistor,
and as this field is made up of two series of N and S electromagnets,
... we have achieved the constant change of the intensity of
the current that flows through the magnetic field formed by the electromagnets
N, and S, and whose current, once that his mission is accomplished in the different
electromagnets, gets back to the source from which it was taken."
Strange. Maybe we have to reconsider some ideas discussed days before.
IMO I think that even if you waste the input current as heat ( 1A at 100 Volts in case of Buforn´s design) I guess you could still get the output to be overunity (20000 Watts, as per Buforn design)
Doug1
Ramaswami
Your Tesla argument is little bit silly . Tesla did at times connect to the grid after it was  produced which he helped to make possible. I have to assume he payed for his use or had it blessed off by someone in authority. Not having first hand proof it is assumed by most what happened when he ventured into the concept to provide free or cheap power to everyone at every point on the planet. That was a time when things were simpler and he didnt fair so well after that. It's easier to prove when your not using the grid then the argument dose not exist. Take it with a grain of salt after all the topic is re-inventing the wheel.
