0 Members and 95 Guests are viewing this topic.
ariovaldo
Quote from: a.king21 on September 30, 2013, 01:52:11 PM
Well... you are starting to sound like the Barbosa-Leal patent from Brazil.
http://www.free-energy-info.tuks.nl/Chapt3.html
about 1/3 rd of the way in the document.
Yes, I know that. I will run some tests with the transformer and I need to find out a place to put the results. This tests will be a mix of everything that I can think about the transformers, like the myths that the magnetic flux will divert and release the primary (Lenz law) if we add a alternative path in the transformer...
Schiko
This was the first look be at my understanding of the original patent.
with all three coils equal, primary and secondary example 200 turns, magnetic wire 18 ... This was my first test.
No load was all normal, but when the secondary is loaded the voltage drops and the primary amperage increases, so far so good as any transformer, but varying the frequency it happens something strange, secondary voltage increases and the primary amperage decreases as there was no great loss but does not reach 100%, and depending on the adjustment of frequency and other parameters comes very close of 100%...
The test was done with just a small laminated core, will be that  affect much the core size, not amperage e voltage but effect FE?  ???
hanon
Schiko,
Watching the shape of your signals I think that maybe your are using resistors of very high value. For that reason you just get high values in the contacts close to the inducer coils (both sides: contacts 1 and 8 ). If you use smaller resistors you could get an increase more steady in your signal. Which is the value of your resistor?
What frequencies are you using in your tests? Remember that Figuera used a small motor to rotate the brush around the commutator. Therefore I guess that he could be used a maximun of 2900 rpm. I  think that his generator does not rely on high frequencies. Maybe he operated his commutator to get comercial 50 Hz AC current (Europe), but this is just my oppinion.  Also remember that he used soft iron cores: I suppose that soft iron has a maximun proper frequency. Does anyone know which is the maximun frequency to be used with soft iron?
a.king21
Re cores:  There's something to add about this.
In a later patent by Bufon, he shows a diagram in which  the cores are less than half way in the primaries.
Also he states  that you can substitute the cores for a coil and this coil will generate voltage which can make the device a self runner.
I tested a solenoid with an ex tv small coil inside instead of the core and it did produce a good current and voltage.
Schiko
Hi Hanon
This photo I took of a post I made here #304  <  Link-1 > has nothing to do with the circuit that I used in the first test was only an outline. The trafo is on the same link is the third picture. And the circuit that I used is this link #288 < Link-2 > controlling 9 Mosfet with resitores of 4 ohms. The frequency was around 30 to 300 Hz.   The waveform did not have peaks as big as those of this photo here. Now I use an H-bridge  I will standby the tests of Ariovaldo.  If ok I'll see if I can get a big transformer to replicate and post too here.
Hi a. king21
It's true, I've seen.
I tried that too but gave the same.
The core I used was the same as the link 1.
cheers
