NoyPi
@cliff
This is why CF device needs resistor.. a quote from CF 30375 patent
"Those who sign, have devised a new method or process for producing
magnetic changes in the core, and this procedure consists of making
intermittent or alternating the current which drives the excitatory
electromagnets, in which case neither the nuclei, nor the induced circuit need
to be moved at all."
Resistor is  helps to create different phases. IMHO
marathonman
 ignacio;
your answer speaks a lot of truth.
NoyPi;
How in the world did you come up with resistors from that???
what i would like to know is ( those who sign) i have been thinking about this on the back burner for many months.
Cliff;
Was it you that stated the Figuera device used DC because there was no phase BS to deal with like with ac.
Doug1
Ramaswami
You could have just said your trying to build a Rife machine in the 40 watt range.
cliff33
Noypi:
You're contradicting yourself. Changing phase can only be done with capacitors or coils. Resistors are immune to phase changes.
Patrick Kelly has a good section on electronic theory.
Marathonman,
Good memory. Ya that was me.
shylo
What if you did 36 alterations per minute?
It should still work right?  As long as there is a change of state, the period of time it takes shouldn't matter should it?
artv
