0 Members and 67 Guests are viewing this topic.
RandyFL
If you look to the left of the threads... there are advertisers. If you wanted to advertise on Hanon's site you should've asked Hanon...if you wanna advertise here " why " ... you should make your own thread. Were trying to get to the bottom of the " Figuera " if you're NOT then you are just as Hanon said........... A noise ....
..................the winner of arguments has to prove it!
All the Best
R
darediamond
Quote from: hanon on March 30, 2016, 10:33:53 AM
I am not God, but at least I am the "creator" of my website I have the "power" to reject your messages asking for money to people. Period. Keep away from me.
Bye ... bye
Yes, it is a thread you created but for what purpose? For the sake of it?
The first time I expressively use the word RAMATRAFOGEN you became angry and criticised me. So the issue is not even about what you saw as an ad in my post. It is about not using the word Figuera an basing comment on it primarily.
If your thread is a tally about providing solution then you would not from at contributors proven ideas expressed o the your thread.
Figuera device can be modified to perform better than was presented in the available patent. I know not how talking about that have become a "noise" to you. Hey, are you from Venus?
Doug1
"Figuera device can be modified to perform better than was presented in the available patent."
  I think the shortest distance between two points is still a straight line not all zig zaggy around a circuit board. It's like mouse traps, everyone has a better version but most of them are mostly better for the person selling them and the mouse who frequently evades the better traps.
NRamaswami
Doug
Straight line is the shortest line between two points is correct. I think I must follow Forest's indication to use high frequency to the primary.
I'm going to use now a secondary coil that can take 120 amps safely and up to 240 amps output and I'm going to use spark plugs in the primary. 300 volts is sufficient for spark plugs to work at less than 0.1 mm distance between the sparks. I'm amazed that we had created 100,000 volts sparks by the rotating charged contacts. We could not make the working rotary device but did make those sparks.
Can you please advise if my precaution of using about 190 meters of secondary coils ( actually 1900 meters of 4 sq mm coils - 10 coils wound together as a twisted coil using available wires and connected in parallel to make a big wire. I believe that I may be able to connect a few secondaries.
I did not know any thing about this information below..See
http://free-energy-info.co.uk/Chapter3.pdf See Page No. 3-6..Prof. Markov's Patent.
"Professor Markov's Transformers
Professor Gennady Markov, General Director of STC "Virus" and author of many inventions and discoveries,
received an international patent for a new a transformer design which he created. His work involves a new law in
the field of physics and electrical engineering. He says: In 1831 Faraday discovered electromagnetic induction.
Then his ideas were further developed by Maxwell. For more than 160 years following that, no one advanced
fundamental electrodynamics by even a single step. Eight years ago, I applied for an international patent, valid in
20 countries, as I had created a transformer, which has already received four Russian patents. My discovery was
made despite the "laws" of the great physicist Faraday who said that "magnetic fluxes in a magnetic circuit should
be combined separately with the resulting combined flux moving in only one direction. Only then can you have a
working transformer".
I dared to do the opposite: take a coil with two identical windings and operate them towards each other. This
creates equal magnetic fluxes, moving toward each other, which cancel each other out, but do not destroy each
other as Faraday and Maxwell claimed. I determined a new law: 'The Principle of Superimposition of Magnetic
Fields in Ferromagnetic Materials'. The superimposition - is the addition of magnetic fields. The essence of the
law is that the magnetic fields are added, cancel each other, but they are not destroyed.
And here the important
part is "they are not destroyed" and that is the key fact on which my law is based."
This part that the flux becomes an additive flux is correct. Net Lenz law appears to be zero but it is actually not the case and Lenz law effects disappears either when the core strength in central is in excess of the primary core Magnetic field strength to when it saturates..
I think only because of the Electromagnetics principles stated Marathonman was earlier saying in this thread that the flux would cancel out if opposite poles are placed against each other. That is not really the case. Secondly this is an open magnetic path core and not a closed magnetic core as in transformers. It may match an induction coil but not a transformer. Turn ratios also do not work.
I have also seen how Ignacio has placed his 4 inductors and created 6 induced. Very intelligent but the flux available in those places is quite weak and we need to use thin wires to get higher voltage but for the same reason we do not get good amperage from those places at lower frequencies of 50 Hz as I have tested so far.
I take the indication from Mr. Forest quite seriously and I will now try with spark plugs to increase the frequency of the primary coils. Neon lamps that would work at 220 volts also can be used as encapsulated spark plugs.
I do not know if the amperage will go up or voltage will go up in secondary. It appears that secondary induced emf would go up. induced emf means only secondary voltage but here if the voltage.
Some times it is better not to know things and just do them and see the results after taking the precautions needed.
I will do this for the month of April and then I will post the results. I will take a Video as demanded by Core. If possible I will also buy watt meters and then show the primary and secondary wattage. I hope the Amperage will go up in secondary. Let us see.
marathonman
A FUCKING SPARK PLUG. what the fuck is wrong with you stupid morons?????? does anyone even read or follow the patents or do you people just pass a tray of crack around and post what ever falls out of your babbling mouths.
I have NEVER in my life ever heard such stupid shit in my life that has come out of your stupid uneducated mouth's of the people on this forum.
i will not sit by and let you stupid fucking morons ruin what so many have strove to accomplish in this forum of Figuera. trying to spread the truth NOT BULL SHIT to people that want to learn.
I personally hope all you fudge sickle bitches get shot by the fuckers that paid you to do so much damage. when my second device is built, the one i am building now i will send it around the fucking world and i hope all you fudge sickle bitches die.
if it's not Figuera GET THE FUCK OFF THIS FORUM !
Doug, Hanon, Randy and others...... i think it's hopeless.
