NRamaswami
Doug:
I have to totally agree with you on the self sustaining part..But you see I'm still learning..I have not studied Electrical Engineering and this feedback has been known to be tough. It is said to be also simple.
I have managed the hard part of getting a higher output than input. This is also verified by Saeed and also shown by Ignacio though he claims to have used identical poles. But it still falls within the principle.
Let me check if I can provide the feedback without risks. If I find a way out I will definitely do it. I'm just looking at a 220 or 230 volt output transformer that can be in phase with the primary and to which input can be given from the secondary. then we need to excite the primary coil through suitable means once and then the power would flow continuously. No moving parts. Fuse and Metal oxide varistor for current and voltage control would do. Let me check if it would work. I need some time to do this..
Some how this project is money draining. My income has come down sharply from the time I have started doing this and health has also gone down. I really do not know why I continue to do this..I have learned how to increase the amperage and voltage of the output from the device considerably. And I'm able to demonstrate both of these independently as well but so far I have not dared to provide the feedback. Let me check if it can be done.
a.king21
N Ramaswami: To loop back is a simple thing.  Just put a spark gap in parallel with the load to prevent runaway.
ignacio
Como pueden comprobar, las personas, intentan alejar de CF. O de los datos buenos.
Las pruebas que hicimos, año 2012, :> Batería de vehículo, inverter, vasos de agua (regular la electricidad) condensador, 4 bobinas de inducción, diodo, (consumo 220volt 0.8amp 176watt )= =) salida 2 taladros de 550watt + lijadora de banda 1200watt, + decapador 500watt, + radial 500watt todo encendido, +cargador de baterías 12volt 10amp.
Salud, se termina tiempo.
As you can see, people, try to stay away from CD. Or the good data.
The tests we did, year 2012:> vehicle battery, inverter, water glasses (regular electricity) condenser, 4 induction coils, diode, (consumption 220volt 0.8amp 176watt) =) output 2 holes 550watt + sander 1200watt band, + stripper 500watt, 500watt + radial everything on, + 12volt 10amp battery charger.
Health, time is up.
darediamond
Quote from: RandyFL on March 31, 2016, 05:49:53 AM
You're pushing yourself into the corner of irrelevance...by your insistence! How odd...
Good Luck in your endeavors...this is the last response.
Bye....Bye
ps Yes MarathonMan its " hopeless "
Seeking " relevance"  on here relates to an haughty heart. Now I see clearly what you guys problem is.  What a surprising revelation!!!
WAAAAAOOO!!
hanon
Let's go back to a constructive debate. We should follow as close as possible what it is written in the patents.
A quote from the 1902 patent:
