marathonman
Hanon;
It doesn't mater if it is one continuous core or separated you still need something to tell you where the field collision is and if you brought it past the secondary far enough.
if you haven't brought the field over far enough in both type cores the output will be reduced considerably.
hanon
I post here a table with design references for coils. You may estimate the core dimensiones (cm x cm) and the turns per volt required for a design maximun power.
Nucleo : core dimensions , square (cm x cm)
Potencia maxima : Maximun power (W)
Vueltas por voltio : Turns per volt
marathonman
As far as i know and read the trains in Barcelona Spain when Figuera moved there were DC because the speed controllers were DC Rheostats. AC controllers were not invented yet, not sure yet on AC to the houses though.
gyvulys666
hanon posted some pages back some pics.attached his original and modified. if we do like this?
hanon
 Hi Gyvulys,
Yes. You are correct. If you read the 1914 patent by Buforn you could see a similar arrangement. You can watch into my site (click on the Globe Sketch under my name in the posts)
Welcome to the thread. I guess you have chosen the most promising thread to follow. Figuera is the man to follow. ;)
