0 Members and 119 Guests are viewing this topic.
marathonman
Yah, that is life. enjoy your laugh, it's what youv'e been doing on this forum for years is laughing at others while your Figuera system runs at home.
and "YES" your right, i will figure the problem out.
cliff33
Marathonman,
"Spilling the beans" sounds like somebody disclosing a big secret lol!
Ya, I know what you mean now. His unit was running on 100 watts of power.
I agree in what you're saying about not using negative, but both my mosfets will only be driven
with a positive going sine-wave signal.
  They will both compliment each other, so that when the gate on one goes more positive,then
the gate on the other goes less positive and vice-versa. The low voltage side of the sine-wave
will always be positive.
Forest,
Not sure if I answered you correctly.
Both mosfets will be driven from the same source so the biasing will be a little bit tricky.
Still working on it.
It takes 3-4 volts to get them to conduct so the bias has to be set accordingly.
   Once working properly, just 2 mosfets will take on the job of 7 power-hungry resistors.
darediamond
Quote from: marathonman on April 10, 2016, 09:06:48 AM
Cliff; "Been doing a lot of thinking about this thing and just wondering why Cf chose such
a high voltage of 550 volts when he could have tested it at 115 volts using only 2 units.
I strongly believe that the higher voltage is the key to the whole thing.?"
Figuera's test as you say were done long before his final device. and you and you person below you should know Buforn spilled the beans about the voltage which is 100 volts @ 1 amp. it could even be an average through one cycle..... who knows. the device can be made to reach what ever voltage and amperage you want, it's not set in stone.
one thing everyone has to consider is that once the primaries are at voltage there needs to be some amount of magnetic field (Capacitance) in the primaries in order to feed Part G when shoved out of the secondary in the declining phase. i could be wrong but if the wire was to big (less windings) wouldn't their be less inductive kick to the Part G for storage.
another thing people are failing to realize is that once this thing is powered up and running that part G becomes the power supply when looped back to it's self feeding the primaries regulating the currant as it spins through reluctance in the core of part G.
if one wanted to make this thing switch with transistors all you have to do is use PNP's on the positive side to mimic rotation as long as they overlap in a make before break fashion. if the transistors are on the other side the inductive kickback from the declining electromagnet being shoved out of the primary will be blocked from feeding part G and therefore it will not be self sustaining.
Hanon;
I am enjoying watching you bang your head against the table. i know you mean well but part G take care of all the currant change. you are over complicating everything.
if everyone is wondering how to get DC from the output that's AC in the figuera device just use Tesla's way and it is simple. no diodes, resistors or anything else needed.
How will the lenzless HIGH FREQUENCY AC OUTPUT from the Center Secondaries be tapped and used if HIGH FREQUENCY Diodes are not first employed to rectify that aforementioned output and then converted back to AC by Simply using an inverter?
Can you explain Mr?
