NRamaswami
Mr. A. King 21
The coils may look CW and CCW wound but the current has to flow in the same direction if it is to produce output in the shape of Figuera device of  straight core.
Lenz is cancelled if Permanent magnet core is used in the device. Magnetic field is already present. You just need to send high voltage to oscillate the existing static field using the resistors. Otherwise DC or pulsed DC will draw high amps V=IR in DC.
It is enough if we oscillate the static magnetic field already present to get a significant output in secondary. The two electromagnets that move towards and away from the central core automatically cancel backemf. I do not know how to draw but backemf of one Primary supports the opposite primary always and both backemf are nullified in the process by the design.
If P1 current goes like this ---> the back emf if <-----. However the P2 current at that time goes like the backemf of P1,. The back emf of P2 likewise goes in the way current moves in P1. Both backemf are therefore cancelled.
If you are using identical poles  a square coil or four coils that are at 90' to the secondary must be placed to tap the output. This is cumbersome and is not indicated by the drawings. I have checked both and this also works but it is easier to do the opposite poles method.
In my view the resistors are there to reduce the current and increase the voltage and the core is a permanent magnet core.
I can do a small experiment if you can advise me how to make steel a strong permanent magnet and that cannot be demagnetized by the current.
forest
Harry Perrigo was a honest man. Nobody is going to put so much efforts into invention and risk his life for a fake device.
You people, already have all the required parts to build Figuera device. It's all on this forum and in patents. Just think a little.
marathonman
I petty much think your all wrong about the Lenz law but that is just my opinion.
the Lenz's law is not thwarted or side stepped at all and a matter of fact Figueras counted on it using it to his advantage.
as the primaries of NN polarity, one is taken up while the other is taken down. the Lenz law states that for every action there is an equal and opposite reaction. so when the declining electromagnet is receding the lenz effect kicks in and causes the field to react in the opposite direction to maintain said field that is already their causing the pressure between the two primary electromagnet to be maintained. as long as the two primary electromagnets are in unison the pressure between the two electromagnets will be maintained also, if not the induction falls off to the lowest peak between them which will be almost nill.
again the Lenz law is not side stepped in the Figuera device and NEVER will be. THIS IS A FACT and can not be refuted and if one had done proper research one will find this to be absolutely true.
PS. i to believe Perrigo to be an honest man.... "BUT" at the present time i am working on the Figuera device and have no time for other devices nor another full time thread.
also the dynamo is  transforming mechanical energy into electricity,  as so stated in the patent. where the electricity comes from is of no consequence because Figuera is referring to the act of not where it is coming from. the "ACT OF" in the present day Generators the system used is turning the generator with a motor and this "ACT OF" is wasteful to no end. so Figuera designed a motionless Generator to remove this "ACT OF" mechanical work to energy thus ending with an very efficient motionless generator.
marathonman
CLICK THIS LINK IF YOU WANT TO KNOW EXACTLY WHAT THE FIGUERA DEVICE IS DOING,  OF COURSE THE SECONDARY IS IN THE MIDDLE.
http://web.archive.org/web/20060525100959/http://www.gocs1.com/gocs1/Psionics/SCALARBEAMER_files/scalarbm3.gif
Exactly as stated in my previous post. imagine that !
Thanks Hanon.
