0 Members and 49 Guests are viewing this topic.
stupify12
The key is already been given to us long time ago. Tesla  called this Rotating Magnetic Induction Machine=Rotating Transformer/Converter=Electro Dynamic Induction Machine.Tesla had use cleverly the Law of Induction Machine on his Motors/Converters/Transformer.
Tesla called this device on a simple term- Egg of Columbus.
All your confusion will be clear ones you will understand the concept behind this device.I think its time to revive this thread again, I already posted this before but nobody seems to take interest.
I know exactly the TPU, Barbosa and Leal Device, Tariel Kapanadze Lenzless Converter,Stanley Meyer VIC,Don Smith Toroid Devices,Clemente Figuera, works exactly the same with this principles.
The Electro Dynamic Induction Machine is wound with 4 coils groups with as 2 sets. Basically we have two Primaries that each primary is wound diametrically opposite with two Coils= 180deg apart on annular ring.
The power supply could be AC and DC.
On DC Supply we need a reversing polarity controller on each coil. We will use the 4 Terminal of the two set of coils on DC Supply. We will need a 4 sequence flip flop switching on this to simulate and replicate the action of an Alternating Current.
On AC Supply we need a TWO phase Alternating Current Generator.We will use only 3 Terminal of the two set of coils, they share common Ground on the 3rd Terminal/Post.
Operation. Lets say: COIL A and COIL B. Lets device this on a 4 quarter cycle.
1. 1st quarter cycle. COIL A(the LEFT-[Positive] AND RIGHT-[Negative] wound coil) is now on maximum magnetic strength, energizing the annular ring fixing the magnetic force of lines 90 Degrees. Now the Magnetic Compass(Pointer) inside the annular ring will point 12 O'clock.
2. 2nd quarter cycle. COL B(The TOP-[Positive] and Bottom-[Negative] wound coil) is now powered by the 2nd phase/lines of supply=flip flop. Is now on maximum magnetic strength while the COIL A is minimum magnetic field.Energizing the annular ring fixing the magnetic force of lines 90degrees. Now the Magnetic Compass(Pointer) inside the annular ring will move to point 3 O'Clock.
3. 3rd quarter cycle. COIL A(LEFT-[Negative] and RIGHT-[Positive] is again maximum magnetic strength but in reverse polarity.Energizing the annular ring fixing the magnetic force of lines 90 degrees. Now the Magnetic Compass(Pointer) inside the annular ring will point 6 O'clock. COIL B on this quarter is minimum strength which means OFF.
4. 4th quarter cycle. COIL B(TOP-[Negative] and BOTTOM-[Positive] is again on its maximum magnetic strength but in reverse polarity. Energizing the annular ring fixing the magnetic force of lines 90Degress. Now the Magnetic Compass(Pointer) inside the annular ring will point 9 O'clock. And lastly repeat the 1st quarter cycle to fully turn or move the magnetic rotation of the Magnetic Compass(Pointer).
I already wanted to reach this to you before. But no one is interested until a man name machinealive had interest on the Rotating Magnetic Field/Rotating Transformer.He is the one you should thank  for he encourage me to post this on this thread. I already give you everything which some has keep as secret. But there is no such thing as new on their invention, the new to this people is using their common sense. There is another form of operation this device that I am still looking for I have not perfectly deduce the magnetic field interactions/magnetic field of lines. Post you opinion and suggestion with pictures is much better.
This device when properly understood is somewhat you guys call the LENZLESS Generator. Don't limit yourself with using only 1 coil windings. Imagination is your limit.I think I have now clear all your confusion.
Background of this Concept.
Read all if you wanted to understand it very much.Please focus on Transformer illustration and drawings. Remember it is powered with TWO Phase Alternating Current Generator. The Induction Motor of Nikola Tesla is the same with this Electro Dynamic Induction Machine/Converter. Some times you can see 4 sets of wire powering this Motor or Converter. You can also see 3 wires with common ground of the two phase alternating generator.
Tesla Patent 381,968 - Electro-Magnetic Motor
Tesla Patent 382,280 - Electrical Transmission of Power
Tesla Patent 390,413 - System of Electrical Distribution
Tesla Patent 382,282 - Method of Converting and Distributing Electric Currents
Tesla Patent 381,970 - System of Electrical Distribution
Tesla Patent 390,414 - Dynamo-Electric Machine
Meow ;D ;D ;D :o 8)
bbem
Quote from: stupify12 on October 26, 2013, 01:38:22 AM
Meow ;D ;D ;D :o 8)
Hello Stupify12.
I just want to say 'thank you very much' for sharing your knowledge about Tesla's ideas and inventions.
I read all your posts at OU- and EF- fora[size=78%].[/size] :)
BTW
Maybe you know the answer to the question of Bruce_TPU:
"[size=78%]How do dual rotating magnetic fields help us?  WHY is that important?  Stop guessing at it and study physics involving said current/magnetic fields and you will find the answer."[/size]
[size=78%]
[/size]
Any idea?
Regards, Bert
Ps. I share your view about the importance of the capacitor (bifilar testla coil beeing capacitor and lenz-less).
stupify12
Quote from: bbem on October 26, 2013, 02:26:58 AM
Hello Stupify12.
BTW
[size=78%]
[/size]
Any idea?
Regards, Bert
::)There is another form of operation this device that I am still looking for I have not perfectly deduce the magnetic field interactions/magnetic field of lines. Post you opinion and suggestion with pictures is much better.  ::)
I already found the answer to that question. Build this machine and experiment  from what you understand on its magnetic field and flow. Once you have understand and build have this machine. Everything will be easy for the dual rotating magnetic field. You can make magnetic flow the TWO Magnetic
It will be easy for you to understand the dual rotating magnetic field=Helix DNA Waveform Generator=Lenzless Generator the most advance cyclotron a physics could think of.
Everything will follow once you fully understand such beast.The Three Primary TPU is a imperfect design they wanted to force to rotate the Magnetic Field,But Tesla did it naturally on his Rotating Magnetic Field Concept.
Meow ;D ;D ;D :o
stupify12
Quote from: hanon on October 20, 2013, 07:27:32 PM
Hi all,
Please check some very interesting posts about Figuera´s generator in the forum at EnergeticForum done in these last days
http://www.energeticforum.com/renewable-energy/12439-re-inventing-wheel-part1-clemente_figuera-19.html
Please post your comments about the proposal discussed in that forum.
http://www.popsci.com/science/gallery/2011-09/archive-gallery-first-appearances-notable-scientists?image=8
Toward the end of the interview, we asked Tesla which arena of science most appealed to him. While we expected him to mention radios and airplanes, Tesla answered that rotating magnetic fields were dear to his heart. "A thousand years hence, the telephone and the motion picture camera may be obsolete, but the principle of the rotating magnetic field will remain a vital, living thing for all time to come."
Doug1
The opposite of consumption is conservation. Conservation is not without activity when the act of conservation is self imposed by the activity.
