0 Members and 52 Guests are viewing this topic.
darediamond
Quote from: hanon on August 08, 2016, 06:16:06 PM
Marathonman,
I tested your simple design to emulate a magnetic resistance exactly as you described. I used laminated magnetic steel wrapped in paper and 30 turns of thick household wire with plastic insulation. I used a 12 volt battery and 2 car bulbs for 12 volts and 5 W (type W5W).  I connected in each side of the coil and in the middle point of the coil. In all cases I got the same ligth intensity in both lightbulbs.
I think that the desired effect is only achived varying the impedance of the system. Intensity = Voltage/Impedance. So you have to vary the inductive reactance,   XL = 2*Pi*Frecuency*L . Therefore if you do not create some frequency it is not possible to get it. I do not know if in a toroidal core with a rotating brush that frequency may be generated. Thus why variacs works with AC.
Tomorrow I will try to upload a video. Now I can post a couple of pictures
PS. If you keep feeding trolls they will come back for more food. You are doing exactly what they want you to do: argue and discredit. It is better to stay quiet.
You who have been schooled severally by respected Goal achievers still keep up with fruitless experiment. Youbcan please keep quiet to let truth reign. I remember how your friend the Kite A.K.A Marathonman, crazily pounce on Ramaswami in the past.
He made a horrible mistake trying that with me because I Dare Diamond an Hardened Truth Seeker Takes No Shit!
The bullshit both of you are promoting here was what Chris Sykes nullified band schooled you on sometimes ago.
Other people on YouTube also gain power Bucking the Secondaries not the Primaries but you Motos are here disrupting things spreading lies in all variations you know.
Are you people humans at all?
wistiti
Marathonman,
Thank you hanon for sharing!
It seem you have the same results as i...
Mabe the split winding on a toroidal core (like in the chapt.3 of pjkbook) work better...? I Will try it when i have some spare time.
Ciao!
marathonman
Marathonman,
I stand corrected, there has to be frequency involved. ops brain fart. that's why the rotating brush set up works through inductive reactance.
so the straight core will work as long as there is a constant change from one end to the other.
good catch Hanon.
Forest; i used resistive wire on my first set up and it got hot with continued use.
Sam6
 Reply #3848 on: August 05, 2016, 12:17:09 AM »
Marathon Man
#3811 on: July 28, 2016, 11:54:32 PM » You said you would PM me regarding methods you use for your 20KW unit. Great! How do you go about that? Unless you have some other method you can use my email...  briceelectric@yahoo.com.
Thanks in advance for your help.
Sam
Considering that Marathon Man has not yet replied to my request for information about his methods for producing a 20 KW Figuera device weighing about 120 pounds, I created a spreadsheet (attached) for designing a Figuera single phase power section. The results show a unit that is much larger than Marathon Man's. It has been explained to me previously that I really don't know what I am doing, so I would appreciate forum members looking this over, pointing out my errors, and showing me how to correct them, as I want to get this right.
Sam
