0 Members and 50 Guests are viewing this topic.
marathonman
forest;  Are you referring to D.C. OR C.F. device.  just curious.
wistiti; your deck need resurfaced and sealed before it gets to bad.   just sayin. your toroid as wound will have a hard time getting a brush to rotate across it. precision is required most in this area.
forest
Quote from: marathonman on August 10, 2016, 05:49:56 PM
D.C. I wonder if C.F. knew the link between his and  D.C., quite possible
currently there are probably 3 people
N.B
C.L
T.K
marathonman
I haven't studied Mr. DC's work but it seams one coil overpowers the other coil and vise verse but not opposing like Figuera. ???
i can't really say one way or the other so ill stick to my ole buddy, ole pal, Figuera.
darediamond
Do not be deceived by there lies in all variations they have been presenting it .
You cannot create a continuous To and Fro Motion in A Motionless Stator applying Direct Current.
At http://jnaudin.free.fr/meg/meg.htm we read:
"An electromagnetic generator without moving parts includes a permanent magnet and a magnetic core including first and second magnetic paths. A first input coil and a first output coil extend around portions of the first magnetic path, while a second input coil and a second output coil extend around portions of the second magnetic path. The input coils are alternatively pulsed to provide induced current pulses in the output coils. Driving electrical current through each of the input coils reduces a level of flux from the permanent magnet within the magnet path around which the input coil extends. In an alternative embodiment of an electromagnetic generator, the magnetic core includes annular spaced-apart plates, with posts and permanent magnets extending in an alternating fashion between the plates. "
The non-zero balance of Ever Effective and efficient Alternate Current creates The needed Motion in Motionless Motor Genertor.
You must led the primaries add up power to create the To and fro or and down movement but you must let the secondaries subtract or cancel out each other to generate lenzless Output Current.
Be Wise.
Part G is a DC to AC converter in mechanical way. But we are in new Era so we need no mechanical inverter again as Solid state DC to AC inverter nowbabounds cheaply.
Be wise.
Do not allow those good for nothing agents of Illuminati or the Olympians or The Committee Of 300 rigth on this thread and other threads keep deceiving you.
They are liars.
Liberate yoyrself.
Figuera, Chris have done his  part. Ramaswami too have. Vladimir Utkin also contributed.
Do your self abfavour by following them.
Wind your Primaries in Attraction Mode  but your secondaries in Repulsion Mode and Utilise AC to activate the Motionless MOGEN youbhave just created.
May you succeed in Jesus name. Amen
Doug1
recommended reading for someone special. http://www.webmd.com/drugs/condition-962-Mental+Disorder+with+Loss+of+Normal+Personality++Reality.aspx?names-dropdown=DE
Chirp chirp
I had to feed it, I just couldnt help it. I felt a moment of sympathy for the under developed. It's like watching the special Olympics you have to be encouraging and tell Timmy he did a great job. Give him some hope that he might find some purpose in life. Let him think he actually matters.
