wistiti
Some good advice or way to go for the rotating contact of the G part??
I have see the variation of intensity in the lightbulb by rotating manually but have hard time to avoid sparking...
forest
Please, stop this maddness. Figuera device can be powered by AC and pulsed DC. Tha's obvious why the latest is powered by pulsed DC, I thought we already discovered why... ?
darediamond
Quote from: forest on August 11, 2016, 11:17:54 AM
Forest are you being forced?
Did you just say AC can be applied to C.F device?
How come you let that out ?
Well there is no madness anywhere but there is  deliberate Deceitful propagandas to prevent people from getting liberated.
When you vibrate Direct Current and Pass it through an Iron Core Electromagnet, what do youngest as output? You wanna tell me it will remain Pulsing DC?
Is there no Iron Core in the Part G?
Is not the Motor driven commutator acting as Vibrator for the  copper wire wound Toroid?
What output do you then get from the toroid?  Pulsing Direct Current Still or ALTERNATE CURRENT?
I request you teach me what I do not 'actually' Know.
NRamaswami
Quote from: wistiti on August 11, 2016, 09:21:09 AM
I think with due respect that the sparking is good.
Assume that the whole of part G is rotated at high speed. I have observed 6 inch long sparks. Very low input of a 12 volt dc is sufficient to get this. Higher the primary voltage higher the secondary output voltage and current.
Is  550 volts sufficient to create a unidirectional spark.
Then the de ception is that the part G and input can be both removed once the part G rotates and creates spark. The primary voltage will be inyially high and then will be reduced.
Pulsed Dc also works and has the disadvantage that it needs high resistance coil to keep the current drawn low. In AC current dawn is is less due to inductive impedance. In Pulseddc this is not available and we need to add high resistance coil to reduce primary current.
Doug..your post is inappropriate and not appreciated. You are highly respected person. You have made many theoretical postulations and none attacked you. Not fair for you to attack others.
Hanon..My guestimate is that some body who has very occassionaly posted here might or could have possibly vuilt the cook device and found it produced pulsed dc or dc. No hard info. No admission it was done but that is my assumption.
Problem is every body talks but no one would give information and are trying in a way to get information of others. Let us post in a constructive way.
